Jerky motion in Z on Maestro
Me too but after few hours 1 hiccup translate into layer shift (in the best scenario)
Printing at 50mm/s non printing moves at 170mm/s
Connected to the Maestro is Panel Due 4,3" and a filament monitor with encoder.Maybe the reduction ration of the extruder (13:1) also is forcing the cpu to produce a lot of steps as the E0 driver is set to 1166steps/mm (microstepping 16x)
@paboman said in Jerky motion in Z on Maestro:
@Veti
1 hiccup
Enough to ruin the printA small number of hiccups should not affect print quality, because each hiccup lasts only 68 microseconds. The step pulse generator pauses for that amount of time to allow the processor to catch up with other tasks. It only does it when the step pulse generator has spent 60 microseconds doing nothing except generating steps.
the machine was printing, (i was doing M122 every 5 minuts) then I heard a strange noise so looked at the print and it was the beginning of a leyer shift.
After that a M122 get me 1 hiccup -
Alex Kenis found that the drivers work strongest at 24v 1/4 x256 interpolation in stealthchop
https://www.youtube.com/watch?v=GVs2d-TOims&t=1012syou will need to find the correct value of v for your setup so that it stays in stealthchop even at 170mm/s
M569 Px Vxxx (for each motor)that is what i would try next
also from your values. you are using a 40 tooth pulley?
this will actually decrease your positional accuracy compared to the more standard 20 tooth pulley.edit:forget that. i miscalculated
Unfortunatelly at 16X interpolated I still get 1 hiccup.
I know @dc42 said it should not affect the print but in my case the 1 hiccup cause a shift in Z resulting into nozzle digging into the print. -
@paboman Did it sound somewhat like this?
https://www.youtube.com/watch?v=8yGIwlT5qc8I wasn't aware of the diagnostics output, so I can't say if there were any hiccups, but I'll give it a look if it happens again. The nozzle didn't hit anything, there were no signs of that on the print. I suspected it did on the second snap, but no melted blobs anywhere suggest it did.
Versions:
Firmware Name: RepRapFirmware for Duet 2 Maestro Firmware Electronics: Duet Maestro 1.0 Firmware Version: 2.02RC4(RTOS) (2018-11-18b5) Web Interface Version: 1.22.5
Specs:
- bigDelta custom printer
- flying extruder
- ~750mm print height
- 400mm print diameter
- 24v
- rattm 17hs8401 1.8deg
- run at 1.3A
- 16x interpolated
Config:
; Configuration file for Duet Maestro (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Sun Oct 07 2018 15:48:41 GMT+0200 (CEST) ; General preferences G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M665 R258.483 L495 B200 H877.95 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X-1.66 Y2.69 Z-1.02 ; Put your endstop adjustments here, or let auto calibration find them ; Network M550 PBigDelta ; Set machine name M551 Pxxx ; Set password M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S0 ; Drive 0 goes forwards M569 P1 S0 ; Drive 1 goes forwards M569 P2 S0 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes backwards M92 X100 Y100 Z100 E2567 ; Set steps per mm M566 X1800 Y1800 Z1800 E1000 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E2500 ; Set maximum speeds (mm/min) M201 X8000 Y8000 Z8000 E1000 ; Set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M350 X16 Y16 Z16 E4 I1 ; Set microstepping with interpolation M572 D0 S0.07 ; Set 0.07 seconds of pressure advance ; Axis Limits M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; Set active high endstops ; Z-Probe M558 P5 H3 F120 T21000 ; Set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z30.323 ; Set Z probe trigger value, offset and trigger height M557 R200 S20 ; Define mesh grid ; Heaters M140 H-1 ; Disable heated bed M305 P1 T100000 B4138 C0 R2200 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C ; Fans M106 P0 S0 I0 F30000 H-1 C"Partfan" ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F30000 H-1 C"PCBfan" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P2 S1 I0 F100 H1 T45 C"Coldfan" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Automatic saving after power loss is not enabled M207 S1.3 F1500 Z0.2 T500 ; Set up firmware retracts ; Miscellaneous G29 S1 ; Load height-map M501 ; Load saved parameters from non-volatile memory T0 ; Select first tool
@duckle I stopped the testing, returned the Maestro and installed the Duet Ethernet...no more skipped steps (like the viedo you posted)
Has there been any other resolution to this issue other then "return the maestro and replace with another duet"?
I'm having the exact issue as shown in
@duckle said in Jerky motion in Z on Maestro:
https://www.youtube.com/watch?v=8yGIwlT5qc8and I'm running out of things to troubleshoot that aren't the Maestro.
@naqaj said in Jerky motion in Z on Maestro:
Send m115 to check that you are running 2.02 firmware, not a 2.02RC version.
I could have sworn I already updated to the late december release, but it did indeed say RC06. I'll try again with 2.02, thanks.
Happy to read that my motion problem was firmware related, I will re-order some Maestro soon!
