    Right way for starting script?
    4.3k
    • perolalarsundefined
      perolalars
      Hi deckingman & Alex9779
      And thanks for reply!
      deckingman, the right extruder (T0) heats up ok (as specified in the starting script) to 150c, but when starting to print the object it remains on 150c not 240c (as in the printing-file).
      Alex9779, first I tried with S3D but it was a lot of strange behaviour so I used Slic3r, all went well, but as said above, it remains on the start script temp not the object print file temp… I dont want to be forced to adjust the printing temperature in the starting script all the time...
      • Alex9779undefined
        Alex9779
        You do not have to if you use variables as I wrote. The variable I wrote in there is S3D syntax. Slic3r has its own. Also Slic3r does remove its own heating commands if you use at least one in your script.
        It was not meant that you insert an actual temperature value there…
        • Alex9779undefined
          Alex9779
          Look here for what is possible in starting scripts for S3D: https://forum.simplify3d.com/viewtopic.php?f=8&t=1959
            perolalars
            Ahhh, great link! Really like to work with S3D instead of Slic3r
            Thanks Alex9779 , will do some more reading then… again...
            • Alex9779undefined
              Alex9779
              Use the forum post listing all the tips of the day posts. There is one for every tab explaining most of the settings. Some are missing because they have been made with an older version…
                perolalars
                @Alex9779 After reading the link you posted I dont quite understand how to make S3D first heat up bed and extruder (using the starting script temperature), then do the probing of the bed, and then take the temperatures from the "printing object" file and start printing the object.
                What would the gcode look if I liked to heat up bed and extruder to 50 (bed) & 150 (extruder) do the probing and then start printing with the bed to (60) and extruder to (240) and use the temperatures from the slicer settings (S3D)? If its possible?
                Sorry but dont understand using varible?!
                • Dougal1957undefined
                  Dougal1957
                  I have found that S3D actually does the start script after the heating cycle and mine has just G32 in the script so when I run a print the bed heats then the hotend then my start script then the rest of the print is executed!
                  Doug
                    perolalars
                    Hi Doug
                    That´s interesting!! I am not at my printer until tomorrow so have to test that then. But do you have some homing cycle first (in the start script)? Before the G32.. I dont want my extruder, with printing distance to the bed, heating up to 240c and then start printing..
                    • Alex9779undefined
                      Alex9779
                      @perolalars:
                      M190 S50
                      M109 S150
                      G32
                      M190 S[bed0_temperature]
                      M109 S[extruder0_temperature]
                        perolalars
                        Okey, thanks a lot!
                        With this I specify the printing temp for the "printing file" witch overrides the settings in the slicer?!
                        • Alex9779undefined
                          Alex9779
                          I don't understand the question, sorry. With this you start with heating. Then the bed is probed. When that's finished the head stay at the last probe position and the bed is heated to the temp you set in the temperature tab. Then the same happens for the extruder.
                          If you want to do the final heating somewhere else insert a G1 command after G32.
                            perolalars
                            Ok sorry for being unclear.
                            When you say "temperature tab" do you mean the settings in S3D?
                            • Alex9779undefined
                              Alex9779
                              Yes that's the whole point of using variables in the script. That way you don't have to change the script every time. It takes the values for the specified heater on layer 1. Each heater has an assigned number normally starting with 0 also on the temp tab. That is the number in the variable…
                                Dougal1957
                                @perolalars:
                                Hi Doug
                                My bed.g file has the home in it and then the autocal routines so it is all in the macro.
                                I have various settings in my S3D Profile for different temps and materials which negates the need to have the temps in the start script I slice using the profile settings I want it waits till first layer temps are reached then runs my Start script and the G32 calls Bed.g macro.
                                HTH
                                Doug
                                • Alex9779undefined
                                  Alex9779
                                  That's right but if you want to move to a specific position before heating like an ooze bucket as I used to have then you can move in the script but S3D does the heating always before your script is executed.
                                  Using those variables disables the automatic heating and you can place it yourself where you want in the startup procedure and do a move first or leveling before heating to the final print temperature…
