    IR Probe and the Fan !?!
    IR Height Sensor
    1.6k
    • Michael Subergundefined
      Michael Suberg
      I'll check the mosfets, I can rule out a short circuit, because the fans have been working for a while.
      I have looked at the datasheet of the Mosfets, these only go up to 30V, but when the fans are switched off, voltages above 24V (My supply voltage) can occur.
      Maybe that's the cause?
      When i use the height map, there is the same problem
        Apart from the DWC message, are there any messages to suggest the the G29 mesh probing failed? If you reload the web interface, are there any error messages in the GCode Console?
          Michael Suberg
          There are no messages in the GCode Console after rebooting
            Michael Suberg
            Can anybody help me further???
              Please post photos of how the IR sensor is mounted and wires to the Duet. Also check that the soldering of the 3 terminals pins on the back of the IR sensor is complete. I suspect a break in the VCC or GND connection to the IR sensor.
                Michael Suberg
                Found a mistake. This only occurs with my ubuntu 16.10 notebook.
                With the phone and windows pc crashes and can show everything.
                The wiring and solder joints are great.
                  dc42 administrators @Michael Suberg
                  @michael-suberg said in IR Probe and the Fan !?!:
                  Did you mean "With the phone and windows pc no crashes and can show everything."?
                  Michael Subergundefined 1 Reply Last reply Reply Quote 0
                    Michael Suberg @dc42
                    Yes, with Windows PC and my Iphone it works well. Mesh Bed works well
                      May I mark this as solved then?
                        Michael Suberg
                        @dc42 said in IR Probe and the Fan !?!:
                        Yes gladly
