    Pause button ghosted
    Duet Web Control
    1.5k
    • Kulitorumundefined
      Kulitorum
      With the new card, I am running the following firmware/DWC:
      And the pause button is still ghosted. (and does not change to "print another" etc when a print completes or a pause with M25...
      Firmware Name:
      RepRapFirmware for Duet 2 WiFi/Ethernet
      Firmware Electronics:
      Duet Ethernet 1.02 or later
      Firmware Version:
      2.02(RTOS) (2018-12-24b1)
      Web Interface Version:
      1.21.2-dc42
        Kulitorum
        And I get the same problem with the Edge browser and Chrome and IE.
          What does the status indicator in DWC say? The pause button will only be shown when the status is Printing.
            Kulitorum
            Status bar (over the pause button) says something in line with "No job running" - while the printer is moving.
            Could it be because I have bad temp readings and is running in "allow cold extrusion" mode?
            Kulitorum
            Kulitorumundefined 1 Reply Last reply Reply Quote 0
              Kulitorum @Kulitorum
              @dc42 this was with DWC 2.0, BTW - I'm back to 1.22.6 now and my status looks like this (while XYZ position is updating)
                Kulitorum
                ok, now I know what you ment. top left corner.
                Status is "Off" - while machine is running.
                Warning in previous image was "Insufficient axies homed", cleared now with a g92 command.
                So now it looks like this:
                  Kulitorum
                  1:43:10 PMM122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet Ethernet 1.02 or later
                  Board ID: 08DGM-917NK-F23T0-6J1DD-3SJ6K-9Z8WG
                  Used output buffers: 3 of 20 (13 max)
                  Static ram: 28532
                  Dynamic ram: 98036 of which 0 recycled
                  Exception stack ram used: 360
                  Never used ram: 4144
                  Tasks: NETWORK(ready,328) HEAT(blocked,912) MAIN(running,3564)
                  Owned mutexes:
                  Last reset 00:04:48 ago, cause: software
                  Last software reset at 2019-02-04 13:38, reason: User, spinning module GCodes, available RAM 4144 bytes (slot 0)
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
                  Error status: 0
                  Free file entries: 9
                  MCU temperature: min 36.4, current 37.1, max 37.4
                  Supply voltage: min 27.8, current 27.9, max 27.9, under voltage events: 0, over voltage events: 0
                  Driver 0: ok, SG min/max not available
                  Driver 1: ok, SG min/max not available
                  Driver 2: ok, SG min/max not available
                  Driver 3: ok, SG min/max not available
                  Driver 4: ok, SG min/max not available
                  Date/time: 2019-02-04 13:43:09
                  Cache data hit count 422742606
                  Slowest loop: 208.22ms; fastest: 0.05ms
                  Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 227, MinFreeDm: 120, MaxWait: 15433ms, Underruns: 0, 0
                  Scheduled moves: 4901, completed moves: 4897
                  Bed compensation in use: none
                  Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
                  Heater 0 is on, I-accum = 0.0
                  Segments left: 1
                  Movement lock held by null
                  http is idle in state(s) 0
                  telnet is idle in state(s) 0
                  file is doing "G1 E1.50 Z100.00 F1200.00 " in state(s) 0
                  serial is idle in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 13.38ms; fastest: 0.01ms
                  HTTP sessions: 1 of 8
                  Interface state 5, link 100Mbps full duplex
                  === Expansion ===
                  • wilrikerundefined
                    wilriker @Kulitorum
                    @kulitorum said in Pause button ghosted:
                    Not the problem you reported but your supply voltage is exceeding the max recommended voltage of 25V. Although this might be working it poses a risk of damaging on-board components. If you can, turn down the PSU a little bit.
                    Manuel
                    My Tool Collection
                      Kulitorum @wilriker
                      @wilriker Nice catch, thank you.
                        Status "Off" means that the VIN monitor thinks the input voltage is below 9.5V. Normally the printer wouldn't be able to run at this voltage, but of course you are using all external drivers and no heaters. Were you powering the Duet from USB or other external 5V power only?
                        • wilrikerundefined
                          wilriker @Kulitorum
                          @kulitorum I also noticed that you are still running a release candidate (RC3) of 2.02. I think you should update to final 2.02 as this might already fix the issue.
                          Manuel
                          My Tool Collection
                            Kulitorum @dc42
                            @dc42 But as you can see, the input voltage is 27.9v.... Maybe I just burned the input regulator-thingy?
                              No, the voltage sensing used to set the state is the same voltage sensing used to display the max/min input voltage.
                              Which firmware version are you using? You said 2.02 earlier, but your M122 report shows 2.02RC3.
                                Kulitorum
                                So.....I guess my Vin could have passed 30v for a while, and burned the input voltage measurement circuit, making the duet think that its underpowered and causing the board?
                                Than again, the M211 command reports : Supply voltage: min 27.8, current 27.9, max 27.9, under voltage events: 0, over voltage events:
                                So....?
                                Kulitorum
                                  Kulitorum
                                  M122
                                  Updated firmware, same result:
                                  4:21:08 PMM122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later
                                  Static ram: 25524
                                  Dynamic ram: 98064 of which 0 recycled
                                  Exception stack ram used: 272
                                  Never used ram: 7212
                                  Tasks: NETWORK(ready,544) HEAT(blocked,912) MAIN(running,3868) IDLE(ready,200)
                                  Owned mutexes:
                                  Last reset 00:01:24 ago, cause: software
                                  Last software reset at 2019-02-04 16:12, reason: User, spinning module GCodes, available RAM 7180 bytes (slot 0)
                                  Error status: 0
                                  Free file entries: 10
                                  MCU temperature: min 36.8, current 37.0, max 37.4
                                  Supply voltage: min 27.8, current 27.8, max 27.9, under voltage events: 0, over voltage events: 0, power good: no
                                  Date/time: 2019-02-04 16:21:04
                                  Cache data hit count 159807234
                                  Slowest loop: 3.65ms; fastest: 0.06ms
                                  I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                                  Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                                  Segments left: 0
                                  file is idle in state(s) 0
                                  === Network ===
                                  Slowest loop: 4.20ms; fastest: 0.02ms
                                    Kulitorum
                                    And its still "OFF"
                                      M122 only shows you the min/max voltage since you last ran M122, or since power up if you haven't run it yet.
                                      I suspect that the voltage reached 29V, which caused the firmware to switch the drivers off to help protect them. They won't be switched on again until the voltage drops to below 27.5V. Since your minimum is 27.8V, that won't happen, so the printer remains in the Off state..
                                        Kulitorum
                                        @dc42 said in Pause button ghosted:
                                        M122
                                        You were right. Taking the voltage down to 26v fixed the problem. thanks.
                                          Kulitorum
                                          Maybe add a warning message to the "!" in the top left corner?
                                          Kulitorum
