Pause button ghosted
Status bar (over the pause button) says something in line with "No job running" - while the printer is moving.
Could it be because I have bad temp readings and is running in "allow cold extrusion" mode?
Kulitorum
@dc42 this was with DWC 2.0, BTW - I'm back to 1.22.6 now and my status looks like this (while XYZ position is updating)
ok, now I know what you ment. top left corner.
Status is "Off" - while machine is running.
Warning in previous image was "Insufficient axies homed", cleared now with a g92 command.
So now it looks like this:
1:43:10 PMM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet Ethernet 1.02 or later
Board ID: 08DGM-917NK-F23T0-6J1DD-3SJ6K-9Z8WG
Used output buffers: 3 of 20 (13 max)
Static ram: 28532
Dynamic ram: 98036 of which 0 recycled
Exception stack ram used: 360
Never used ram: 4144
Tasks: NETWORK(ready,328) HEAT(blocked,912) MAIN(running,3564)
Owned mutexes:
Last reset 00:04:48 ago, cause: software
Last software reset at 2019-02-04 13:38, reason: User, spinning module GCodes, available RAM 4144 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0440f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
Error status: 0
Free file entries: 9
MCU temperature: min 36.4, current 37.1, max 37.4
Supply voltage: min 27.8, current 27.9, max 27.9, under voltage events: 0, over voltage events: 0
Driver 0: ok, SG min/max not available
Driver 1: ok, SG min/max not available
Driver 2: ok, SG min/max not available
Driver 3: ok, SG min/max not available
Driver 4: ok, SG min/max not available
Date/time: 2019-02-04 13:43:09
Cache data hit count 422742606
Slowest loop: 208.22ms; fastest: 0.05ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 227, MinFreeDm: 120, MaxWait: 15433ms, Underruns: 0, 0
Scheduled moves: 4901, completed moves: 4897
Bed compensation in use: none
Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
Heater 0 is on, I-accum = 0.0
Segments left: 1
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is doing "G1 E1.50 Z100.00 F1200.00 " in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 13.38ms; fastest: 0.01ms
HTTP sessions: 1 of 8
Interface state 5, link 100Mbps full duplex
=== Expansion === -
@kulitorum said in Pause button ghosted:
Not the problem you reported but your supply voltage is exceeding the max recommended voltage of 25V. Although this might be working it poses a risk of damaging on-board components. If you can, turn down the PSU a little bit.
@wilriker Nice catch, thank you.
Status "Off" means that the VIN monitor thinks the input voltage is below 9.5V. Normally the printer wouldn't be able to run at this voltage, but of course you are using all external drivers and no heaters. Were you powering the Duet from USB or other external 5V power only?
@kulitorum I also noticed that you are still running a release candidate (RC3) of 2.02. I think you should update to final 2.02 as this might already fix the issue.
@dc42 But as you can see, the input voltage is 27.9v.... Maybe I just burned the input regulator-thingy?
No, the voltage sensing used to set the state is the same voltage sensing used to display the max/min input voltage.
Which firmware version are you using? You said 2.02 earlier, but your M122 report shows 2.02RC3.
So.....I guess my Vin could have passed 30v for a while, and burned the input voltage measurement circuit, making the duet think that its underpowered and causing the board?
Than again, the M211 command reports : Supply voltage: min 27.8, current 27.9, max 27.9, under voltage events: 0, over voltage events:
So....?
Kulitorum
M122
Updated firmware, same result:
4:21:08 PMM122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet Ethernet 1.02 or later
Static ram: 25524
Dynamic ram: 98064 of which 0 recycled
Exception stack ram used: 272
Never used ram: 7212
Tasks: NETWORK(ready,544) HEAT(blocked,912) MAIN(running,3868) IDLE(ready,200)
Owned mutexes:
Last reset 00:01:24 ago, cause: software
Last software reset at 2019-02-04 16:12, reason: User, spinning module GCodes, available RAM 7180 bytes (slot 0)
Error status: 0
Free file entries: 10
MCU temperature: min 36.8, current 37.0, max 37.4
Supply voltage: min 27.8, current 27.8, max 27.9, under voltage events: 0, over voltage events: 0, power good: no
Date/time: 2019-02-04 16:21:04
Cache data hit count 159807234
Slowest loop: 3.65ms; fastest: 0.06ms
I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
Segments left: 0
file is idle in state(s) 0
=== Network ===
Slowest loop: 4.20ms; fastest: 0.02ms
Interface state 5, link 100Mbps full duplex -
And its still "OFF"
M122 only shows you the min/max voltage since you last ran M122, or since power up if you haven't run it yet.
I suspect that the voltage reached 29V, which caused the firmware to switch the drivers off to help protect them. They won't be switched on again until the voltage drops to below 27.5V. Since your minimum is 27.8V, that won't happen, so the printer remains in the Off state..
@dc42 said in Pause button ghosted:
M122
You were right. Taking the voltage down to 26v fixed the problem. thanks.
Maybe add a warning message to the "!" in the top left corner?
Kulitorum
