    Quick microstepping configuration question.
    689
    • Wyvernundefined
      Wyvern
      Stupid simple question, this is my code.
      I would like to configure E to 32 microstepping no interpolation, I see ( I ) means interpolation, If 1 means all how do I deselect E but keep the others on?
      • aidarundefined
        aidar
        Like this:
        M350 X16 Y16 Z16 I1
        M350 E32 I0
        • Wyvernundefined
          Wyvern
          Sweet, thanks.
          There is no issue running interpolation at 32X correct? This is a Cartesian and is far from computationally demanding.
          I'm getting a .9 stepper soon (direct hobbed) and will be going back to 16X, but I'm just trying to see what it does.
            On the Duet Ethernet/WiFi, interpolation only works at x16. You can ask for interpolation at other microstepping settings, but it will be ignored.
            On the Duet Maestro, interpolation works at all microstepping settings.
            Wyvernundefined 1 Reply Last reply Reply Quote 0
            • Wyvernundefined
              Wyvern @dc42
              Cool, thanks, so technically I can just change E on that one line of code and all is well?
                dc42 administrators @Wyvern
                @wyvern said in Quick microstepping configuration question.:
                Yes.
                • Wyvernundefined
                  Wyvern
                  Cool.
                  The second you answered me, the mail truck just delivered my new stepper, go figure! E3D doesn't grind a flat in their shafts!?
                  Thanks, I will try posting results 16X 32X 1.8 deg, and 16X .9 deg.
                  • Wyvernundefined
                    Wyvern
                    So I did the tests, need to take some pics still, but;
                    1.8 16x interpolation- good results some minor banding when shining light above it- naked eye it looks great.
                    1.8 32X no interpolation- OK results, fares worse than 16X, looks like a normal ramps board printed it.
                    .9 16X interpolation- best results so far, only slightly better than 16X 1.8.
                    I will say with the .9 stepper cranked to 1.4A (max 1.7) it gets pretty noisy on the retract/prime, but 1A exhibits skipped steps.
                    currently adjusting steps/mm It seems like it extrudes just a tiny bit more when simply doubling the stepps/mm
