Buzzing stepper (extrusion)
    Stoop
    I've setup an additional stepper driver (drv8825) and configured it in firmware.
    all ms pins are high
    M584 X0 Y4 Z2 E3:5 ; Apply custom drive mapping
    M350 E16:32 I0
    I've set M569 P5 S1 T4 as well
    But it buzzes and doesn't turn.
    I've got a1 a2 b2 b1 attached to red blue green black respectively.
    where am I going wrong?
      Wyvern
      What is your M906 settings?
      Are you getting errors from duet control/due when operating the stepper?
      Could be miswired/poor connection or amps are too low.
        Stoop
        I haven't setup M906 for it, it's an external stepper. Does it apply? I thought I just used the little pot on the stepper driver.
        undefined 1 Reply Last reply 5 Feb 2019, 21:19 Reply Quote 0
          Phaedrux Moderator @Stoop
          @stoop M906 won't apply to an external stepper that doesnt use an SPI interface. The adjustment pot is the way to go.
          Have you verified the coil pairs, either with a multimeter or by touching the ends together and turning the shaft by hand?
          1 out of 4
