Z +- 0.05 or 0.1 not available via phone web control
Duet Web Control wishlist
    CozyP
    Hi all,
    I was using an old duetwifiserver file and I changed to the latest one, 1.22. I noticed that when I try to control Z axis through web on my phone ( iOS safari ) only +- 0.5, +-5 and +-25 are available.
    This is kinda nuisance when try to position the Z axis manually before the start of every print, as the 0.5 movement is HUGE.
    Is there any possibility to change this manually?
    Thank you for your time!
      What version of DWC and firmware are you using?
      You should be able to specify the baby stepping amount in Settings > User Interface tab.
      https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual#Section_User_Interface
        CozyP
        I didn\t know that you could change the values with right click. DAYUM!!!
        Thanks
          NeoandGeo
          Also when you change one side with right click, the other side reflects the change too.
          3 out of 4
