Pulse Width
Is there any way to set pulse width from the DuetWifi?
....For?
We are getting lost steps when we move at higher speed. So we are wondering if fixing the pulse width can overcome the issue of lost steps.
You can set the step pulse parameter using the T parameter in the M569 command. You don't need to change the pulse width when using the drivers that are built-in to the Duet, but you do need to when using most types of external driver.
