    Fans stopped working
    • Jasonpgrundefined
      Jasonpgr
      I was rerouting some wires adding a cable chain and during this process I think wires came loose because my part cooling fan and heat sink fan wouldn’t turn on when I fired up the machine again. If at some point things came lose and the fan wires shorted to each other or something, would that fry those outputs on the board? I checked for visual damage and saw none but I’m not getting any voltage on my meter from the “always on” output or the F0 output.
      Wyvernundefined 1 Reply Last reply Reply Quote 0
      • Wyvernundefined
        Wyvern @Jasonpgr
        @jasonpgr Depending on your board you may have a fan fuse.
        • Jasonpgrundefined
          Jasonpgr
          I believe I have the newest version of the duet WiFi. The board is about 8 months old. Where would I look for a fan fuse and what would it look like?
            Phaedrux Moderator @Jasonpgr
            @jasonpgr said in Fans stopped workinf:
            If it's the version 1.03/1.04 board there would be a blade fuse right by the fan connectors.
            https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
            • Jasonpgrundefined
              Jasonpgr
              That did the trick, thanks so much! Pulling that fuse out was a bitch since it was in there so toght, but it did finally come loose and I swapped it out. Fans are cruising along now. Thanks again!
