    IDEX Issues
    1.4k
    • iDeveloundefined
      iDevelo
      So i've finally had chance to get the BCN3D Sigma setup and near enough working apart from one issue. I can't use the right extruder to print!
      It will move fine using G1 U30 etc… and it will home as expected.
      When i try to print with the right extruder it will extrude the filament as it's printing but it just won't move, it heats fine aswell.
      My config:
      ;;;;;; General preferences ;;;;;;
      M111 S0                                               ; Debugging off
      G21                                                   ; Work in millimetres
      G90                                                   ; Send absolute coordinates
      M83                                                   ; but relative extruder moves
      M555 P2                                               ; Set firmware compatibility to look like Marlin
      M584 Y1 E3:4 Z5 X0 U6                                 ; Driver Mappings
      M208 U0 X-48 Y-3 Z0 S1                                ; Min
      M208 X209 Y294 Z286 U257 S0                           ; Max
      ;;;;;; Endstops ;;;;;;
      M574 Y1 S0
      M574 Z0 S0
      M574 X1 S0
      M574 U2 S0
      M574 E1 S0
      M558 P5 X0 Y0 U0 Z1 H5 F120 T6000                     ; Set Z probe type
      G31 P500 X0 Y0 Z0 U0                                  ; Set Z probe trigger value, offset and trigger height
      ;;;;;; Drives ;;;;;;
      M569 P0 S0                                            ; X
      M569 P1 S1                                            ; Y
      M569 P6 S0                                            ; U
      M569 P3 S1                                            ; E0
      M569 P4 S0                                            ; E1
      M569 P5 S1                                            ; Z
      M350 X16 U16 Y16 Z16 E16:16 I1                        ; Configure microstepping with interpolation
      M92 X80 U80 Y80 Z1600 E492.45:492.45                  ; Set steps per mm
      M566 X600 U600 Y600 Z60 E120:120                      ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 U6000 Y6000 Z680 E1200;1200                ; Set maximum speeds (mm/min)
      M201 X1000 U1000 Y1000 Z1000 E250:250                 ; Set accelerations (mm/s^2)
      M906 X950 U950 Y800 Z900 E1000:1000 I30               ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30                                               ; Set idle timeout
      ;;;;;; Heaters ;;;;;
      M143 S280                                             ; Set maximum heater temperature to 280C
      M570 S150                                             ; Set maximum heating time to 150s
      M305 P0 T100000 B4138 C0 R4700 L0 H0                  ; heater 0
      M305 P1 T100000 B4388 C0.0000000000000000 R4700 L0 H0 ; heater 1
      M305 P2 T100000 B4388 C0.0000000000000000 R4700 L0 H0 ; heater 2
      M307 H0 A64 C371.6 D5.6 B0
      M307 H1 A344.7 C122.8 D5.5 B0
      M307 H2 A344.7 C122.8 D5.5 B0
      ;;;;;; Tools ;;;;;;
      M563 P0 D0 H1 X0                                      ; Define tool 0
      G10 P0 X0 Y0 U0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                          ; Set initial tool 0 active and standby temperatures to 0C
      M563 P1 D1 H2 X6                                      ; Define tool 1
      G10 P1 X0 Y0 U0 Z0                                    ; Set tool 1 axis offsets
      G10 P1 R0 S0                                          ; Set initial tool 1 active and standby temperatures to 0C
      ;;;;;; Network ;;;;;;
      M550 PBCN3D Sigma                                     ; Set machine name
      M552 P0.0.0.0 S1                                      ; Enable network
      ;;;;;; Fans ;;;;;;
      M106 P0 S0.3 I0 F500 H-1
      M106 P1 S1 I0 F500 H1 T45
      M106 P2 S255                                          ; Board fan
      M106 P5 S255                                          ; LED
      M106 P6 S255                                          ; LED
      M106 P7 S255                                          ; LED
      Any ideas? I've had this working before on the BIG printer so i know it's something i'm doing wrong, i just can't put my finger on it.
      • iDeveloundefined
        iDevelo
        My mistake was:
        Should have been:
        M563 P1 D1 H2 X3                                     ; Define tool 1
        I presumed X was the drive number, not the axis number!
        • r123undefined
          r123
          So, how is Duet working out on the Sigma?
          That printer has a lot of vibration when in full flow: can imagine you might see some improvements in print quality?
          • iDeveloundefined
            iDevelo
            It's cut the noise down no end 🙂
            Prints are a lot lot better
            • iDeveloundefined
              iDevelo
              This was printed at 80mms. It looks a little rough due to the glitter in the filament.
              • r123undefined
                r123
                well done, looks like you have yourself a dream machine!
                the standard BCN has a neat levelling setup: what are you doing for levelling now?
                • iDeveloundefined
                  iDevelo
                  Well for the Z offsets i do it manually. It's fairly easy to do. To get the bed level i use the same method as BCN3D do by using both Z microswitches and working out the difference. It's manual in respect to working out which knob to twist but it's not a big issue.
