DUET WIFI for dispenser machine
2.2k
    gavatron3000
    depending on what your dosing the supporting infastructure is where the cost is, i do industrial maintenance and used to work in a DVD manufacturing plant. the resin dosing heads were relatively simple like the one you show above but the vacuum systems and deforming tanks where the resin had the bubbles removed and was filtered was worth a fortune.
    just some info if your curious
      Alishkus
      @dc42 they do not provide exact power needed for solenoid, only this spec sheet
      I assume easiest way would be to use 12V relay and use fan output. As heater is PID or can I turn of PID?
      @gavatron3000 I already have this info. There are to different things. One when you have continuous manufacturing and you need resin degassed in line process (that is bloody expensive) and other process is where you degass resin manually and fill it to pressurized container. Thats pretty cheap.
        If the power consumption is only 4W or 4.2W as specified in that data, you can run it directly from a fan output.
          Alishkus
          Looks like it is 4.2W as they don not mention any other consumption only for solenoid.
          So basically I could control dispenser with M106 S0/S1 and fan outputs if I understood good.
          Another thing that bothers me is G-Code generating. What I need is basically a line in space.
          It is all clear with 2D lines. I generate G-Code. Edit it manually when to start and when to end dispensing. I make some macros to find X0/Y0/Z0. Wollia.
          What is more interesting its 3D line in space. I can draw it, but I dont really understand what program to use to generate Gcode for 3D line.
          Anyone has experience with it?
            Alishkus
            @dc42 I have a question.
            I want to use 12V fan output to control 24V 4.2W (166mA) solenoid.
            I would use booster for 12V output to have 24V. It will become ~400mA.
            Am I allowed to do that?
            undefined 1 Reply Last reply 15 Feb 2019, 08:43 Reply Quote 0
              dc42 administrators @Alishkus
              @alishkus said in DUET WIFI for dispenser machine:
              I don't advise that, because the boost converter will have a high starting current, which might blow the mosfet. Can't you either use a 12V solenoid, or power the Duet from 24V?
                Alishkus
                @dc42 ok, going to buy 24V power supply. Will be less problems.....
                  Alishkus
                  So its is working 🙂
                  Will update on process of project as its pretty nice use of Duet Board 🙂
                    Alishkus
                    @dc42 can I have some consultation? 🙂
                    Machine is working (only compressed air hook up left) but I have strange behavior....
                    When I upload Gcode duet executes it normally, buuuuut it wont execute -X lines.... So it moves only half X distance needed. Am I missing something here?
                    Head travels from X100 to X0 and then it decides to move to Y direction...
                      Have you used M208 in config.g to define the X axis limits?
                      undefined 1 Reply Last reply 21 Feb 2019, 10:20 Reply Quote 0
                        Alishkus @dc42
                        @dc42 and yes you are right 🙂 Thanks
                          Alishkus
                          Look at these perfect lines :))
                          Machine works, however Fusion 360 is still not really suitable for Duet board. I will try to do some configuration on Fusion and if it will work will post here 🙂
                          19 out of 21
