    Control Panel invalid password
    • Lupoundefined
      Lupo
      Hello, I was setting up my new duet wifi and I can not connect to the web interface. The machine says the password is invalid even though it's the exact same as the one I get from the M503 command. Any help is appreciated.
        Try a different password (not the one you really want to use), and if it still doesn't work, post the M551 line you used in config.g and the password you enter in DWC here.
        • Lupoundefined
          Lupo
          works fine with a new password, thanks
            If the password you were trying to use includes any accented characters, that should work provided that you write the config.g file in UTF8 encoding.
