    temperature sensor on smart effector board
    Hardware wishlist
    962
    • c310undefined
      c310
      i suggest implementing temperature sensor on smarteffector board not too far from the center
      reason:
      in case water or air cooling device (fan or pump) fails, and you are not next to the printer (as usual) 🙂 firmware would emergency stop the print if board is over 60 degrees or so.
      without such a sensor and in case of failure smarteffector would be burned and even can start real fire...
      mine fan failed, but thanks to god i was near and noticed strange smell...
        A nice idea. However, we'd need to replace the 8-pin connector by a 10-pin connector. Then we'd probably need to go for a smaller pitch connector to make room for it - which would mean we need to supply a pre-wired cable, because smaller pitch connectors are harder to crimp.
        • c310undefined
          c310
          or add extra 2pin connector . red.
          or extend microfit connector that now hosts power for 2 fans and hotend
            dc42 administrators @c310
            @c310 said in temperature sensor on smart effector board:
            There are already a lot of connectors on the Smart Effector. Adding another one would make to harder to disconnect, and we'd need to find room for it.
            We deliberately separate the high voltage (fan/heater) connections from the low voltage (sensor) connections, to reduce the risk of wiring shorts.
            • c310undefined
              c310
              another option -
              take 2 pins out of 4 from PT100. Now it has 2 pins on the connector (however PT100 connector uses only 2 pins, as well as recommended sensor). 4 wire sensor is way to big to fit into standard hotend AND safety is more than PT1000 🙂
                There are benefits to using a 4-wire PT100 connection even with a 2-wire sensor. In particular, it stops the resistance of the connector contacts affecting the temperature reading.
                Your suggestion of a separate 2-pin connector would preserve compatibility with the existing product, but a smaller 10-pin connector would be a neater solution.
                • c310undefined
                  c310
                  @dc42 is there a plan for next generation of Duet and SmartEffector? 🙂
                  • DocTruckerundefined
                    DocTrucker
                    This came up a few days ago:
                    https://forum.duet3d.com/topic/9309/dc42-just-thought/3
