    Ender 3 using DUET 2 Maestro w/Panel Due 5i (Homing Issue)
    • bfpa40undefined
      bfpa40
      I have a Ender 3 printer which I just installed the DUET 2 Maestro on. My first question is there someplace online that has a guide for what to setup in the RepRapFirmware for this Printer? I am having issues with homing. Is the home position where the endstop switches are located? My X axis moves away from the endstop switch when i press the X Home Button once arriving there grinds and tries to continue causing me to have to power off the printer. Now when I press the Y Home button the hotbed travels toward the endstop switch but once arriving there grinds and tries to continue causing me to have to power off the printer. The Z axis when i press the Z Home button it travels 2.50 units upward and stops each time I press Z Home.
      I know there has to be someone who can offer guidance as to what to do in order to get me started in the correct programming sequence.
        https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches
        https://duet3d.dozuki.com/Wiki/Test_homing_behaviour
        https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter
        These links should help.
        I believe that endstop switches will need to be wired to the 2 outside pins of the connector.
