    24V Thermostatic Fan and 5V Print Cooling Fan Connections
    1.2k
      deckingman @Jackal
      @jackal
      Everything you need to know is here - https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
      • Jackalundefined
        Jackal
        I did read the page before and the closest thing seems to be this (for 12V fan in 24Vin)
        Put a jumper on V_FAN at the VIN end. Wire the buck regulator input to an always-on fan output. Wire the positive wires of 12V fans directly to the buck regulator output, and the negative wires to the FAN- pins of the controlled fan outputs as usual
        So instead of a buck convertor, can I use the on board 5v and can I connect them in parallel.
        edit: wiki seems to be referring to always-on instead of thermostatic, still not sure if it can be applied to my case.
        edit 2: Got another paragraph regarding this but I still want confirmation just to be safe
        Mixed-voltage setups are not directly supported on the Duet 2 WiFi/Ethernet, but the Duet switches the fans' connections to ground, so you may be able to connect each fan's positive side to the appropriate voltage and its negative side to the appropriate pin on the Duet. Each controlled fan can be configured in firmware as a gcode controlled fan or as a thermostatically-controlled fan.
        • SupraGuyundefined
          SupraGuy
          Second paragraph that you found is accurate.
          Duty cycle switching is all done at the ground side, so you can connect multiple positive voltages to different fans, and the Duet will switch the ground side for control. I am running both 12V and 24V fans, with plans to run all fans at 12V once I get around to switching out the remaining 24V units.
          Lead screw driven printer, powered by Duet 2 Wifi
          MPCNC powered by Duet 2 Wifi
          CoreXY printer driven by Duet 3 6HC
          LowRider CNC powered by Duet 2 Wifi
          • Jackalundefined
            Jackal
            Thanks for the confirmation
              deckingman @Jackal
              @jackal Always on fans are, as the name implies, always on. You can't control them (because they are always on). So everything else apart from supply voltage in the wiki applies to fans that are not "always on".
              • Jackalundefined
                Jackal
                Just to report that I have connected my two 5v fans in parallel and +ve to on board 5v and -ve to Fan2-
                Everything seems to working fine, tested with M106 P2 S255.
                So worried that I was gonna fried the board, I killed the thermistor fuse not long after the board arrive so please bare with my paranoia.
                  deckingman @Jackal
                  @jackal It's better to be overly cautious IMO. ☺
                    If you have fans of different voltages on your system, then V_FAN must be the highest fan voltage. In your case that's 24V, so put the VFAN jumper in the VIN position. Connect your 24V fan as normal.
                    To connect the 5V fans, connect the red wire to +5V (which you can get for the spare pin of the VFAN jumper block) and the black wire to the FAN- pin of the chosen 2-pin fan connector.
                    • Jackalundefined
                      Jackal
                      Thanks for the VFAN jumper 5v suggestion, that makes the wiring a bit cleaner
                        dc42 administrators @Jackal
                        @jackal, be very careful not to short +5V to +24V !
                        • Jackalundefined
                          Jackal
                          I am very careful with the more obvious stuff, just not sure when it involves adding resistors/dioides or splitting the +ve -ve connections.
