    Laser turns of during straight lines
    Laser Cutters
    2.4k
    • Zandrundefined
      Zandr
      Version 2.02 from 24 december
        Please try 2.03beta2, and if it still happens with that version then I will try to reproduce that issue.
        Zandrundefined 1 Reply Last reply Reply Quote 0
        • Zandrundefined
          Zandr @dc42
          @dc42 hi i have now installed the latest beta firmware and i am having the same issue it will blink on at the start of the line but wont stay on until the line of g code finishes. I ran another test witht the circle and found that if i slow my travel speed down it will fire for every line of code like a pulse not a continus beam. Thanks for your help.
          • Zandrundefined
            Zandr
            Hi should i try and increse the frequency from 200 to 2000? On the jtech controler website the max control frequency is 5 KHz? Thank you in advance.
              I will look into this tomorrow. Can you confirm that you have connected the laser controller + and - control signal input terminals to the heater +VIN and E1- outputs on the E1 terminal block? Does the laser run continuously if you connect those control wires to the VIN terminal block (or an always-on fan output) instead?
              • Zandrundefined
                Zandr
                I have the + in the E1- and the - in an end stop ground. if i connect the + to the VIN on the Heater E1 the laser stays on permanently but will blink off for a second if i send an M3 S255 command. I can invert the signal from the controller as it has an invert / non invert pin.
                Should i wire it the way you have described " laser controller + and - control signal input terminals to the heater +VIN and E1- outputs on the E1 terminal block"
                It could be the way i have wired it stopping it working as it should but wont know til i am home from work at 5pm GMT
                  dc42 administrators @Zandr
                  @zandr said in Laser turns of during straight lines:
                  Yes. The datasheet you linked to says the control input can be anywhere between 2.8V and 36V and it is digitally isolated, so that should be safe to do. Set the inversion on the laser controller so that when the E1 heater LED is off, the laser is off too. Then set the I parameter in the M452 command to get the on/off signal right (I0 should be correct).
                  That appears to be a good laser controller, better than the usual ones with TTL compatible inputs.
                  • Zandrundefined
                    Zandr
                    Thank you i will give it a shot what should i set the Frequency value at?
                    • Zandrundefined
                      Zandr
                      I am also having an issue when homing z in laser mode should i start a new help topic?
                        I suggest around 2kHz.
                        Yes.
                        • Zandrundefined
                          Zandr
                          hi again @dc42 i have set my laser up like you described but still have the issue where the laser blinks at the start of the line but wont stay on until the move has finished.
                          I have wired it laser controller + to the VIN and the - control signal input terminalE1- outputs on the E1 terminal block.
                          changed the laser settings to this:
                          ; LASER SETTINGS
                          M307 H2 A-1 C-1 D-1 ; disable heater 2 to make it available as a general purpose output pin
                          M452 P2 I0 R255 F2000
                          still running this line g code
                          G21
                          M03 S0
                          G0Z0.0010
                          G0X0.0000Y0.0000
                          G0X14.3143Y50.0000Z0.0010
                          M3 S200
                          G1X83.3143Z-0.0010F1000.0 S200
                          M05
                          G0Z0.0010
                          G0X0.0000Y0.0000
                          I also put another m3 s200 comand before the m5 comand and the laser flashes when it reaches the end of the line move, it is as if the m3 comand is not latching on to continue to provide power until it reaches the end of the line move/ or the m5 comand.
                          • Zandrundefined
                            Zandr
                            I did some more tests thismorning, the only way to get a line is for me to enter g code for every 1 mm move and the laser will fire for every line of code. This is silly to do for a straight line hope u agree. I can draw a circle with the laser as there are multiple lines of code to form the circle. Hope this info helps in some way.
                              So far I have not been able to reproduce this. Please provide your complete config.g and homing files.
                              • Zandrundefined
                                Zandr
                                Config G
                                G90 ; Sent absolute coordinates
                                M550 PWorkBee CNC Machine ; Set machine name
                                M552 S1 ; Enable network
                                M586 P0 S1 ; Enable HTTP
                                M586 P1 S0 ; Disable FTP
                                M586 P2 S0 ; Disable Telnet
                                M569 P0 S0 ; Drive 0 goes forwards
                                M569 P2 S0 ; Drive 2 goes forwards
                                M584 X0 Y1:3 Z2 ; Apply custom drive mapping
                                M92 X400 Y400 Z400 ; Set steps per mm
                                M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
                                M566 X500 Y500 Z500 ; Set maximum instantaneous speed changes (mm/min)
                                M203 X2500 Y2500 Z2500 ; Set maximum speeds (mm/min)
                                M201 X150 Y150 Z150 ; Set accelerations (mm/s^2)
                                M906 X2400 Y2400 Z2400 I100 ; Set motor currents (mA)
                                M208 X800 Y770 Z94 S0 ; Set axis maxima
                                M574 X2 Y2 Z2 S0 ; Set active low endstops
                                ; LASER SETTINGS
                                ; Custom settings
                                M564 H0 ; Enable jog commands when not homed
                                M140 H-1 ; Disable heated bed
                                M501 ; Load Stored Parameters
                                M563 P1 S"XYZ-Probe" ; Define XYZ Touch Probe Tool
                                Home All
                                ; homeall.g
                                ; called to home all axes
                                ; generated by RepRapFirmware Configuration Tool on Mon Mar 12 2018 16:19:25 GMT+0000 (GMT Standard Time)
                                G91 ; relative positioning
                                G1 H1 Z94 F900 ; move quickly to Z axis endstop and stop there (first pass)
                                G1 Z-3 F2400 ; go back a few mm
                                G1 H1 Z94 F300 ; move slowly to z axis endstop once more (second pass)
                                G1 H1 X1500 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 X-3 Y-3 F2400 ; go back a few mm
                                G1 H1 X1500 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
                                G90 ; absolute positioning
                                Home x
                                ; homex.g
                                ; called to home the X axis
                                G1 H1 X1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 X-3 F2400 ; go back a few mm
                                G1 H1 X1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
                                Home y
                                ; homey.g
                                ; called to home the Y axis
                                G1 H1 Y1500 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 Y-3 F2400 ; go back a few mm
                                G1 H1 Y1500 F300 ; move slowly to X and Y axis endstops once more (second pass)
                                Home z
                                ; homez.g
                                ; called to home the Z axis
                                G1 H1 Z94 F1500 ; move quickly to Z axis endstop and stop there (first pass)
                                G1 H1 Z94 F300 ; move slowly to Z axis endstop once more (second pass)
                                • Zandrundefined
                                  Zandr
                                  https://www.dropbox.com/s/bvmhu6aodccqmqt/Video 25-03-2019%2C 4 32 20 pm.mov?dl=0
                                  Added a video hope this helps also. If you look between 20 and 30s into it you can see where i have tried to do a simple HI text and the straight lines within the text dont complete, i will do another video showing that.
                                  Thank you
                                  • whosrdaddyundefined
                                    whosrdaddy
                                    I don't know if it makes a difference but you did not home your axes in your video, maybe try homing them first?
                                    • Zandrundefined
                                      Zandr @whosrdaddy
                                      @whosrdaddy thank you but i homed before i started just didnt show it in the video and then set the work once and then realised i coudent get a good video so moved and set work zero again. Thanks tho 🙂
                                      • Zandrundefined
                                        Zandr
                                        https://www.dropbox.com/s/nmfwcr52qj705u3/Video 25-03-2019%2C 7 41 59 pm.mov?dl=0
                                        Circles work ok 1000mm/min
                                        • Zandrundefined
                                          Zandr
                                          https://www.dropbox.com/s/85r4dxatwe89pzq/Video 25-03-2019%2C 7 54 05 pm.mov?dl=0
                                          Same circle at 20mm/min is it corect that it should flick on and off? Per g1 move
                                            I still can't reproduce the problem you describe, but I've found an error in your GCode. You have this in config.g:
                                            The relevant commands in your GCode file are:
                                            G0 X14.3143 Y50.0000 Z0.0010
                                            M3 S200
                                            G1 X83.3143 Z-0.0010 F1000.0 S200
                                            The last G1 command has endpoint Z=-0.0010 but you have set the Z minimum to zero. So that command is to an out-of-bounds position and it won't be executed. You should get an error message in the console.
                                            Zandrundefined 2 Replies Last reply Reply Quote 0
