    Duet Laser Filament Monitor
    • Marine85undefined
      Marine85
      I am trying to calibrate my duet laser filament the LED is pulsing but when I send M591 D0 shows this
      Duet3D laser filament monitor v1 on input 10, disabled, allow 35% to 180%, check every 5.0mm, no data received
      and when I Enable S1 too little movement reported .
      and print pauses.
      Software Information
      Firmware Electronics: Duet WiFi 1.02 or later + DueX2
      Firmware Version: 2.03beta2 (2019-02-16b1)
      WiFi Server Version: 1.22
      Web Interface Version: 1.22.6
      ; generated by RepRapFirmware Configuration Tool on Tue Aug 21 2018 21:22:04 GMT+0400 (Arabian Standard Time)
      M550 PYOUNES ; Set machine name
      M551 Pteignprop ; Set password
      M552 S1 ; Enable network
      M587 S"TEIGNBRIDGE" P"peacock1" ; Configure access point. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes forwards
      M569 P1 S0 ; Drive 1 goes forwards
      M569 P2 S0 ; Drive 2 goes forwards
      M569 P3 S0 ; Drive 3 goes forwards
      M569 P4 S0 ; Drive 4 goes forwards
      M569 P5 S0 ; Drive 5 goes forwards
      M569 P6 S0 ; Drive 6 goes forwards
      M584 X0 Y1 Z2:3:4:5 U3 V4 W5 E6 ; Apply custom drive mapping
      M671 X-284.5:-284.5:1455.5:1455.4 Y-222.8:1318.4:1318.4:-222.8 S20 ; Bed levelling using multiple independent Z motors , CW Z1(close to homming front right) Z2(rear right) Z3(rear left) Z4(front left)maximum correction 20 mm
      M350 X16 Y16 Z16:16:16:16 U16 V16 W16 E16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z640:640:640:640 U640 V640 W640 E442 ; Set steps per mm
      M566 X900 Y900 Z12:12:12:12 U12 V12 W12 E120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z180:180:180:180 U180 V180 W180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y20 Z250:250:250:250 U250 V250 W250 E250 ; Set accelerations (mm/s^2)
      M906 X1450 Y1450 Z1850:1850:1850:1850 U1850 V1850 W1850 E600 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S120 ; Set idle timeout
      M208 X1200 Y1200 Z1200 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops (NC)
      M591 D0 P5 C10 S1 R35:180 E5.0 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 10-11 (CONN_LCD), tolerance 35 to 180%, 5mm comparison length
      M591 D0 ; display filament sensor parameters for extruder drive 0
      M307 H3 A-1 C-1 D-1
      M574 Z1 S2 ; Set endstops controlled by probe
      M558 P5 X0 Y0 Z1 T4000 F300 H10 I1 ; Set Z probe type to switch and the dive height + speeds(Analog Z probe, also used for homing the Z axis), I for polarity with NPN
      G31 X0 Y0 Z0 P500 ; Set Z probe trigger value, offset and trigger height
      M557 X15:1150 Y15:1150 S100 ; Define mesh grid
      M143 H0 S100 ; Set temperature limit for heater 0 to 100C
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M303 H1 S240 ; auto tune heater 1, default PWM, 240C target or maximum temperature
      M303 ; report the auto-tune status or last result
      M570 S120 ;After a heater has been switched on, wait 120 seconds for it to get close to the set temperature. If it takes
      longer than this, raise a heater fault.
      M307 H1 A413.5 C245.5 D5.5 B0
      M307 H0 A75.4 C170.1 D0.5 B0 ; Auto tuning for Bed heaters
      M106 P0 S0 H-1 C"Part Cooling" ; Set fan 0 (Part cooling blower) G-code controlled. Thermostatic control is turned off
      M106 P1 S1 H1 T45 C"Hotend Fan" ; Set fan 1 (Hotend fan) Thermostatic control. Turns on when hotend reaches 45c
      M106 P2 F100 L0.2 B0.5 T30:40 H100:101:102 C"Duet Fans" ; Set fan 2 Duet case fan. Tied to CPU and driver temps.
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      M501 ; Read stored parameters
      T0 ; Select first tool
        You need to do a print to calibrate the sensor (with the sensor disabled i.e. S0 in the M590 command) then M590 D0 will display the accumulated calibration data too. But the "no data received" message suggests a wiring or configuration error.
        • Marine85undefined
          Marine85
          Thanks, I will do a print and check
          • Marine85undefined
            Marine85
            the Issue is with the Data out from the laser filament sensor to CONN_LCD to pin 10)Stp 11(LCD_DB4) no Data receiving!
            when I connect the sensor out to E0 STOP works flawlessly.
            is my configuration C10 is correct ?
            Thanks,
            Ibrahim
              dc42 administrators @Marine85
              If you connected it to STP11 then you need C11 in that command, not C10.
              Marine85undefined 1 Reply Last reply Reply Quote 0
              • Marine85undefined
                Marine85 @dc42
                @dc42 Solved!
                it looks like I was using wrong Pin for data , it works now with CONN_LCD
                4) STOP 11 (ENC_A)
                M591 D0 P5 C311 S1 R30:130 E5.0
