Resurrect goes missing
I have a RMXv4 delta printer, and have seen the resurrect prologue on the SD card before.
Was going to test it today, and there are no resurrect files anywhere on the card.
I can reinstall it easy enough, but I know what's going to happen, when I need it, it will have disappeared.
The printer company said printers go out with the file on the SD card.
I visited this issue when I had a power outage, and no files on the printers SD card on my other printer (RMX3.2)
What would make it disappear?
The resurrect-prologue file is one that you have to create yourself (except perhaps if you buy the Duet as part of a printer kit and the supplier includes it), because its contents are highly dependent on your printer. The resurrect.g file is created when a print is paused for any reason, and deleted when a print finishes normally. See https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure.
ok, thank you for the post, I'll just try it during a print, and see if the file generates
