7" PanelDue
1.6k
    cap
    hi thanks for paneldue it arrived safe and sound today panel v2 first thing i want to ask before i touch anything is
    i have the 7inch touch screen so the jumper pin needs to be left as 3.3v and NOT moved to 5v on the panel due board
    also if you point me at a good place to set this up as i can not find much in the documentation
    many thanks
    warning brain may explode
      iDevelo
      https://miscsolutions.wordpress.com/paneldue/
        Yes leave the jumper at 3.3V. The backlight of the 7" panel takes 5V but it gets that through a separate connection.
        For setup see https://miscsolutions.wordpress.com/paneldue/.
          cap
          thanks thats a great blog love the details and the pic do help
          do the new v2 come with new firmware are do i need to update it
            If you bought the screen and the PanelDue together, then hopefully it will have the correct firmware installed already. If you bought them separately then you will need to install the 7" version of the firmware on it.
              cap
              thanks
              bossac program did not work on my windows 10 even messing with compatibility setting DOH!!
              anyway i dug out and old note book with vista on and the job is done happy days
              (never thought id be happy to use vista)
                You can use bossac.exe from the Tools folder of my github repo under Windows 10. I need to update the instructions, or else build a new version of bossa.
                4 out of 7
