HTTP timeout from laptop but not phone/tablet
Hi, thanks for letting me be part of this community.
Problem:
HTTP request has timed out, occurs only on my Macbook. Works fine from smartphones and tablets. I'm not sure how to proceed and I would appreciate any help, thanks!M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
Board ID: 08DGM-9T6BU-FG3S0-7JKF0-3S46Q-KU47D
Used output buffers: 3 of 20 (14 max)
Static ram: 28380
Dynamic ram: 95864 of which 0 recycled
Exception stack ram used: 348
Never used ram: 6480
Task NETWORK ready, free stack 324
Task HEAT blocked, free stack 1256
Task MAIN running, free stack 3568
Last reset 00:04:56 ago, cause: power up
Last software reset at 2019-04-08 18:50, reason: User, spinning module GCodes, available RAM 6440 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
Error status: 0
Free file entries: 10
SD card longest block write time: 0.0ms
MCU temperature: min 33.7, current 33.7, max 34.0
Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0
Date/time: 2019-04-08 21:36:37
Slowest loop: 181.61ms; fastest: 0.08ms
Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
Scheduled moves: 7, completed moves: 7
Bed compensation in use: none
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is idle in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 4.40ms; fastest: 0.01ms
HTTP sessions: 1 of 8- WiFi -
Network state is running
WiFi module is connected to access pointÂ
Failed messages: pending 175, notready 0, noresp 0
WiFi firmware version 1.21
WiFi MAC address 84:f3:eb:83:32:f4
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 14224
WiFi IP address 192.168.1.105
WiFi signal strength -34dBm, reconnections 0, sleep mode modem
=== Expansion ===
confitg.g
; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 Pe3 ; Set machine name
M552 S1 ; Enable network
;*** Access point is configured manually via M587
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwards
M92 X80 Y80 Z400 E95 ; Set steps per mm
M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (mm/min) was 1200 you changed it to 600
M203 X30000 Y30000 Z300 E1500 ; Set maximum speeds (mm/min)
M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
M906 X500 Y500 Z500 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S300 ; Set idle timeout; Axis Limits
M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
M208 X258.5 Y246 Z260 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S1 ; Set active high endstops; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
G31 P25 X-31 Y0 Z.6 ; Set Z probe trigger value, offset and trigger height
M557 X50:185 Y50:185 S65 ; Define mesh grid M557 X20:215 Y20:215 S65; Heaters
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H0 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings
;M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance ;10 to 120%, 3mm comparison length - WiFi -
I see you're running an older version of the firmware and wifi server. You might see some better results by updating to the 2.02 firmware.
https://github.com/dc42/RepRapFirmware/releases/tag/2.02
To upgrade from firmware 2.0 or later, upload the Duet2Firmware-2.02.zip file through the Settings/General tab of Duret Web Control. This file also includes Duet Web Control 1.22.6 and DuetWiFiServer 1.21.
https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02b.zip
Thanks, I will try that as soon as I get back home. I appreciate the help!
