    Tool change script S3D TEMPERATURE
    1.3k
    • johnjohn1990undefined
      johnjohn1990
      I put a dollar sign in the S command when i used s3d...
      M109 S$
      Dont know if this works for you though...
      JVundefined 1 Reply Last reply Reply Quote 0
        johnjohn1990
        Or use M116 which is the reprap gcode for it, as far as i have understood
          Why not use the RepRapFirmware tool change files instead? Then all you need to do is use G10 to set the active and standby temperatures at the start of the print, and at any layers where you want to change the extrusion temperature(s).
          JVundefined 1 Reply Last reply Reply Quote 1
          • DanLundefined
            DanL
            @dc42 blasted with new info at every turn....
            As a noob I'm exhausted from all the searching so far just to get all the basic print functions working. Is there any one -stop-shop to get at least an index to all the Duet Gcode setup info? As I search I keep finding tangent, but relevant info, (like your tidbit about tool change files use) and pretty soon I'm in a do-loop. It's kind of like having a 1000 page user manual with the pages scattered all over the floor.
            e.g., I have everything coded and working now with all T's in the S3D start up script. Simple question....can pretty much all process settings be done with Duet (tool files) and just bring in a S3D generated .stl? Maybe not even a valid question....tired and confused...late here.
            DanL
              A good place to start is https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter. If your printer isn't a Cartesian, then read the pages applicable to your printer geometry too.
              Detailed information on each particular G- and M-code command is at https://duet3d.dozuki.com/Wiki/Gcode.
              DanLundefined 1 Reply Last reply Reply Quote 0
              • DanLundefined
                DanL @dc42
                @dc42 Yes, thanks...have used those extensively...and Duet 3D Documentation. And Google.
                But for a noob, even simple stuff can be a struggle. Still can't figure out why I can't change the status of my simple mswitch filament out sensor. S1 or S2 setting makes no difference. It will operate only as NO.
                Also, paused a print....wonder of wonders! It worked! And I was thinking all along I had to write some macro to make it work. And do I need to write a filament out macro? Or is there already a predefined action?
                And then the bed scan/compensation...no problem...works like a champ. And I thought that would be a huge headache.
                Just tons of those little questions that pop up.
                But really, Duet WiFi is soooo much better than dealing with Marlin (which was also new to me). The Duet hardware, interface, etc are great. And once you get this all working, it's pretty straightforward. Still on the learning curve, but first prints looking good so far.
                One more thing....the support here is really good. Thank you. I'm just a bit tired....
                DanL
                  dc42 administrators @DanL
                  @danl said in Tool change script S3D TEMPERATURE:
                  Does the filament present/not present status reported by M591 D# (where # is the extruder drive number) change depending on whether you use S0 or S1?
                  The SD card we ship with Duets includes pause.g and resume.g macros. They may be suitable as-is for some printers. A filament-out condition currently also runs pause.g.
                  Thanks for the feedback!
                  • JVundefined
                    JV @dc42
                    @dc42 thanks, i'll try to do it as you said
                    and i"ll let you know
                    • JVundefined
                      JV @johnjohn1990
                      @johnjohn1990
                      Thanks John i'll check if dollars sign works.
                      And i'll let you know
                      • DanLundefined
                        DanL
                        Apologies for the rant and for the extreme hijack. Was a bad evening....
                        Sorry.
                        DanL
                        • JVundefined
                          JV
                          @dc42 But it is possible to set the temperature in the S3D and not in the tool change file in the RRF each time that i print some part with diferent material?
                            Yes of course it is. You can configure the temperatures for each extruder independently in S3D. No need to set temperatures in either the RRF tool change files or in S3D tool change scripts.
