    Is there any 8th Extruder Heater output pin?
    • Rievundefined
      Riev
      If I want to use 8 Extruder, I can use 2 Stepper Drivers on Duet2 Wifi + 5 Stepper drivers on Duex 5 + 1 Stepper Driver from CONN_LCD pin on Duex 5 = 8 Stepper Drivers.
      And I can use 4 pcs PT100 Daughter Boards that have 8 total input pin PT100 temperature sensor.
      But, for Extruder Heater Output Pin I only found 2 pins on Duet 2 Wifi + 5 pins on Duex 5 = 7 output pins.
      I need 1 Extruder Heater output pin more so I can use total 8 Extruders.
      Is there any 8th Extruder Heater pin on Duet2 Wifi/Duex 5 that I can use?
        There isn't an 8th extruder heater output, however in RRF 3 I can increase the maximum number of heaters so that you could use one of the fan outputs on the Duet to drive a heater via a mosfet switch or SSR. Of, if you are already using an SSR to drive the bed heater, you could drive that from a fan output and connect an extruder heater to the bed heater output.
        • Rievundefined
          Riev
          Can you give me some guide for set up the fan outputs in RRF3?
          Actually I have already using a SSR for drive the Bed Heater, I'm not intend to switch bed heater output to extruder heater output.
          I think I need 1 external mosfet more to drive 8th extruder heater as you suggested.
            dc42 administrators @Riev
            @arief said in Is there any 8th Extruder Heater output pin?:
            See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview. Please note, you will need to wait until I make a new beta available later today in order to configure more than 8 heaters.
            What iImeant is that as you are using an SSR to drive the bed heater, and an SSR input can be driven by a fan output, then using RRF 3 you can reassign heater 0 to to a fan output. Then the bed heater output will be free for your extra extruder heater, and you won't need an external mosfet.
