    Precision Piezo PT1000 sensor?
    Third-party add-ons
    • Samuel_kundefined
      Samuel_k
      Hi all,
      I bought a couple of Precision Piezo PT1000 sensors that I'm planning to use together with a Maestro, but the temperatures are off by quite a bit. I taped down a trusted E3D thermistor to the heat block to check the readings, and even though they give the same reading at room temp, the PT1000 thinks that 100°C is at 83°. The PT1000 is configured using M305 P1 X501.
      I've found lots of other threads about PT1000 issues with various other sensor suppliers, but not this one, and since it seems to be quite common among Duet users I wonder if there's something off with my sensors. How does everyone else configure them? Is it a lost cause to get them working on an ADC channel, and should I just bite the bullet and tune them in as thermistors instead? (ping @DjDemonD 🙂 )
      • Moriquendiundefined
        Moriquendi
        You need to specify the value of the series resistor in order to get accurate readings
        M305 P1 X501 R4700 ; Specifies a 4.7k resistor for the Duet Wifi
        M305 P1 X501 R2200 ; Specifies a 2.2k resistor for the Duet Maestro
        Idris
          dc42 administrators @Moriquendi
          @moriquendi said in Precision Piezo PT1000 sensor?:
          Idris
          That shouldn't be necessary, because the default values are correct for all Duets except the Duet 085 and some Duet 06.
            Moriquendi
            Is that a recent firmware feature?
            Idris
              Idris
              RepRapFirmware for the Duet WiFi, Ethernet and Maestro have always had the correct default values. The Duet 06/085 has the default set to 1K because the Duet 06 originally used 1K resistors, but that was changed to 4.7K in later Duet 06 boards and in the Duet 085.
