    ATX Power off at 45° at the Heatend
    • SWundefined
      SW
      Hy at all, ✌
      how can I switch ATX power off when the Hotend is under 45°C, because the Fan from the Coldend need ATX-Power and I dont want to damage my Printhead!
      If my print is finish I have to wait bevore the system shut down with ATX-Power off. Any Idea?
      • gtj0undefined
        gtj0
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M81_ATX_Power_Off
        If you give the S1 parameter to M81 it'll wait until the fans turn off before shutting the ATX power off.
        • SWundefined
          SW
          Thank you for this information!
          Do you mean i have to write into the End-sequence for my progamms (Slicer Cura) M81 S1 to shut off the ATX-Power?
          • gtj0undefined
            gtj0 @SW
            @sw Yep. That should do it.
            • SWundefined
              SW
              Oh yes, I thank You very much and check it now ... 😎
