IDEX printer, 2nd extruder stuck at original layer height
    tstarkengineering
    IDEX printer,
    First layer everything looks great. 2nd layer and beyond, 1st extruder keeps changing per designated layer height, 2nd extruder stays at original layer height.
    After 10 layers or so. 1st extruder is on layer 10, 2nd extruder is trying to lay down layer 10 at layer 1 or 2 height
      Which electronics and firmware are you using?
        tstarkengineering
        Ill check on the firmware version but one of the fairly newest.
        Duet wifi
        5x
        Bl touch
        Been playing around with g31, and g10 on both extruders
          tstarkengineering
          Opps duet 2 wifi
            Do you have a large Z offset configured for one of your tools in G10?
              tstarkengineering
              Actually no. Now i tried again and now skirt lays down perfect layer on both extruders, then layer 1 is now 2mm above build platform
              3 out of 6
