cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems
Hi there i hope someone here can help me :(. I seem to have a few problems at the moment i am upgrading my cr-10s with the duet 2 wifi with a ac powered 230v 750w bed im using a KZLTD KS1-25da SSR i have everything wired but cant get steppers working and my heated bed starts heating up but then i get the "heating up to slow" error i have changed the heat up time from 180 to 195 seconds my hotend heats up no problem my endstops work when pressed i get the "yes" i have sent the
G91
G1 S2 X-10G91
G1 S2 Y-10G91
G1 S2 Z-10commands and they move my motors but they still wont home
i have swapped the motor connections aroung in case it was that but still the same thing :(i am using a 12v power supply hope i havent left anything out
thaks for any advice.
post All your configurations
sorry but how do i do that
im a right noob
is that the config.g file??
@jobesynoob1234 yes and all homing files too
; Configuration file for factory testing Duet Ethernet and Wifi with V2.02 firmware
FOR TESTING ONLY! USE https://configurator.reprapfirmware.org/ to generate configuration files for your printer!
; Communication and general
M111 S0 ; Debug off
M550 PDuetTest ; Machine name and Netbios name (can be anything you like)
M551 Preprap ; Machine password (used for FTP)*** Ethernet networking: The following lines are used for factory testing - PLEASE REMOVE THEM
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
M552 P192.168.1.14 ; IP address
M554 P192.168.1.255 ; Gateway
M553 P255.255.255.0 ; Netmask;*** End of factory test lines to be removed
;*** Networking
M552 S1 ; Turn network onM555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
M83 ; ...but relative extruder moves; Disable Fan 1 thermostatic mode
M106 P1 H-1; Axis and motor configuration
M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
M665 R105.6 L215.0 B85 H250 ; set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping with interpolation
M92 X80 Y80 Z400 ; Set axis steps/mm
M906 X1000 Y1000 Z100 E750 I60 ; Set motor currents (mA) and increase idle current to 60%
M201 X3000 Y3000 Z100 E1000 ; Accelerations (mm/s^2)
M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute; Thermistors
M305 P0 T100000 B3950 R4700 H120 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B3974 R4700 H300 L0 ; Put your own H and/or L values here to set first nozzle thermistor ADC correction
M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set 2nd nozzle thermistor ADC correctionM570 S195 ; Hot end may be a little slow to heat up so allow it 180 seconds
; Adjustments for dummy heaters on test rig
M307 H0 A250 C140 D5.5 B1
M307 H1 A250 C140 D5.5 B0
M307 H2 A250 C140 D5.5 B0; Fans
M106 P1 S-1 ; disable thermostatic mode for fan 1; Tool definitions
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a single-nozzle build, comment the next 2 lines
//M563 P1 D1 H2 ; Define tool 1
//G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E80:80 ; Set extruder steps per mm; Z probe and compensation definition
;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command.
M558 P4 F100 T6000 X0 Y0 Z0 H3 ; Z probe is a Smart Effector and is not used for homing any axes R0.4 not used. Reduced F300 to 100
G31 P100 X0 Y0 Z-0.25 ; Set the zprobe height and threshold for Smart Effector;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation hereM208 S1 Z-0.2 ; set minimum Z
T0 ; select first hot end
; M117 Use https://configurator.reprapfirmware.org/ to set up your printer config -
@dragonn said in cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems:
homing files
homing files?? where are they
You should really read the first line of you config file.
think i found them
; Example Homing file for RepRapFirmware on delta printer
;G91 ; use relative positioning
;******* Change F250 in the following line to F2500 when you are finished commissioning
;******* Change 320 in the following to a higher value if your Kossel has taller towers
;G1 S1 X320 Y320 Z320 F2500 ; move all carriages up 320mm, stopping at the endstops
;G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
;G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
;G1 Z-5 F2000 ; down a few mm so that we can centre the head
;G90 ; back to absolute positioning
;G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate -
i have used the reprap configuration tool and as far as i know i uploaded it to the duet
is that what u mean ?
Duet2CombinedFirmware.bin is the file i believe
@jobesynoob1234 yes, it seems that you did upload it wrong, maybe into the g-code page and not into system.
Pleas post what firmware version are you running (Main firmware, Wifi Server and Web Control) -
@jobesynoob1234 No it is not, this is a file for updating the firmware, not configuring it.
Firmware Version: 2.02(RTOS) (2018-12-24b1)
WiFi Server Version: 1.22
Web Interface Version: 1.22.5 -
Pleas post the zip. file what you are getting from the reprap configuration and make some screens how do you upload it.
how do i upload the firmware because its saying i cant upload it in that format
i mean how do i post it
sorry
@jobesynoob1234 said in cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems:
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find themthats a delta printer configuration.
please discard all your configs and start from new with the configurator
oooops that sounds like a big mistake
what will i do now
do i select the corexy?
