    IR Probe broken?
    • pedrinidundefined
      pedrinid
      Hello from Italy.
      Last month I purchase a genuine IR Probe and connected to one DuetWifi.
      Initially, it seemed to work well, three days after it stop working. 4 Blinking led when starting, then nothing.
      From the electronic scheme I checked every individual components and solders, everything seems to work correctly except the infrared emitter most distant from the capacitor. At this terminals I have 1.2 volts but no voltage drop on resistor, it does not absorb any current.
      With my IR checker I only find one working IR emitter. Is it faulty?
      I have been waiting for a response from customer service for two weeks.
      many thanks
      Daniele
        dc42 administrators @pedrinid
        @pedrinid said in IR Probe broken?:
        Hello from Italy.
        many thanks
        Daniele
        Yes it sounds faulty to me. Did you buy it direct from duet3d.com, or elsewhere?
        pedrinidundefined 1 Reply Last reply Reply Quote 0
        • pedrinidundefined
          pedrinid @dc42
          @dc42 said in IR Probe broken?:
          Hello from Italy.
          many thanks
          Daniele
          No, makerdise.
          It say that " it behaves like you did create a short on the backside of it. What happened to the cable on the left side in the video - it looks like it isn't attached to the connector. Did you use a crimp tool? The bolts you use for fixing are 2 big. "
          https://www.youtube.com/watch?v=F9aX3BntJ34&feature=youtu.be
          The signal pin (white) in this video was extracted during removal. The screws are the ones in the box.
            Please tell Makerdise that I approve replacement of that IR sensor under warranty.
            • pedrinidundefined
              pedrinid
              ok, many thanks.
              • makerdiseundefined
                makerdise
                @dc42 @pedrinid - Ok, we will send out a new as a replacement, it doesn't make sense to return the old as the shipping costs are to high.
                The biggest european Duet3D reseller
                https://www.makerdise.com
                • pedrinidundefined
                  pedrinid
                  @makerdise said in IR Probe broken?:
                  I agree. Thanks for your support.
