Manual G29/bed compensation
    johnjohn1990
    Is it possible to make a manual bed compensation with duet?
    A regular g29, just manual for each point?
      A Former User
      if you choose no z-probe it will go through the auto probe steps, but display a jog screen on the web interface (and on the panel due if you have one) so you can adjust the bed up and down for each point with a piece of paper or something.
      undefined 1 Reply Last reply 25 May 2019, 14:09 Reply Quote 1
        johnjohn1990 @A Former User
        @bearer said in Manual G29/bed compensation:
        Sweet!
        I currently just use a normal endstop at z min..
        So i should just enable mesh compensation, with no z probe? 🙂
        undefined 1 Reply Last reply 25 May 2019, 14:56 Reply Quote 0
          dc42 administrators @johnjohn1990
          @johnjohn1990 said in Manual G29/bed compensation:
          Yes, with the Z probe type set to "none", which is P0 in your M558 command in config.g.
          2 out of 4
