    Print time estimates unavailable with cura gcode
    2.3k
    • burtoogleundefined
      burtoogle
      I am giving cura a go (the latest version, 2.3.1) and notice that the web display just shows all of the time estimates as n/a and also the % complete bar above is shown as 100% all the way through the print. Is this because cura requires the use of absolute extrusion distances?
      Cheers,
      Mark
        It probably means that they have changed or removed the comments in the gcode file that describe the filament needed and other important parameters that RRF needs to work out the estimates. Post the first and last 50 or so lines of your gcode file (the ones that are all comments) and we should be able to confirm thus.
          burtoogle
          Start of file…
          ;FLAVOR:RepRap
          ;TIME:1451
          ;Generated with Cura_SteamEngine 2.3.1
          M190 S60
          M104 S205
          M109 S205
          G28 ; home all axes
          G1 X-85 Y70 Z0.2 F8000;start of wipe
          G92 E0
          G1 E5 F500
          G92 E0
          G1 X-120 Y5 Z0.1 F8000;end of wipe
          G1 E-3 F1800
          G92 E0
          G1 X-120 Y5 Z50 F8000
          G1 E3 F1800
          G92 E0
          M82 ; extruder absolute mode
          ;LAYER_COUNT:69
          ;LAYER:0
          M107
          G1 F1800 E-3
          G1 Z20.5
          G0 F3600 X4.176 Y11.706 Z.695
          ;TYPE:SKIRT
          G1 Z.195
          G1 F1800 E0.1663
          G1 F3000 X-4.481 Y11.672 E0.50318
          G1 X-5.059 Y11.63 E0.52574
          G1 X-5.563 Y11.526 E0.54576
          G1 X-8.911 Y10.62 E0.68073
          G1 X-14.231 Y9.434 E0.89284
          G1 X-20.252 Y8.461 E1.13018
          G1 X-20.816 Y8.33 E1.15272
          G1 X-21.357 Y8.122 E1.17527
          G1 X-21.864 Y7.841 E1.19783
          G1 X-22.327 Y7.494 E1.22034
          G1 X-22.657 Y7.176 E1.23818
          G1 X-25.323 Y4.31 E1.3905
          G1 X-25.688 Y3.859 E1.41308
          G1 X-26.024 Y3.289 E1.43882
          G1 X-26.39 Y2.538 E1.47134
          G1 X-26.607 Y2.001 E1.49387
          G1 X-26.728 Y1.543 E1.51231
          G1 X-26.825 Y1.071 E1.53106
          G1 X-26.902 Y.497 E1.5536
          G1 X-26.905 Y.01 E1.57255
          G1 X-26.869 Y-.688 E1.59975
          G1 X-26.8 Y-1.263 E1.62228
          G1 X-26.57 Y-2.043 E1.65393
          End of file...
          G1 X-14.19 Y-8.392 E914.81047
          G1 X-14.181 Y-8.402 E914.81101
          G1 X-14.099 Y-8.454 E914.81488
          G1 X-13.803 Y-8.641 E914.82737
          G1 X-13.622 Y-8.7 E914.83374
          G1 X-13.39 Y-8.776 E914.84016
          G1 X-13.104 Y-8.794 E914.84619
          G1 X-12.917 Y-8.806 E914.84892
          G1 X-12.671 Y-8.806 E914.85176
          G1 X12.858 Y-8.806 E915.52891
          G1 X13.143 Y-8.806 E915.53346
          G1 X13.348 Y-8.767 E915.53809
          G1 X13.585 Y-8.722 E915.54464
          G1 X13.852 Y-8.596 E915.55484
          G1 X13.984 Y-8.533 E915.55965
          G1 X14.29 Y-8.281 E915.57409
          G1 X14.324 Y-8.253 E915.57577
          G1 X14.363 Y-8.199 E915.57843
          G1 X14.582 Y-7.898 E915.59179
          G1 X14.644 Y-7.739 E915.59765
          ;TIME_ELAPSED:1451.115048
          G1 F1800 E912.59765
          M107
          M83 ; extruder relative mode
          M104 S0 ; turn off extruder
          M140 S0 ; turn off bed
          M106 S0 ; turn off fan
          G28 ; home
          M84 ; disable motors
          M104 S0
          ;End of Gcode
          ;SETTING_3 {"global_quality": "[general]\nversion = 2\nname = Kossel XL 200um
          ;SETTING_3 \ndefinition = custom\n\n[metadata]\nquality_type = normal\ntype
          ;SETTING_3 = quality_changes\n\n[values]\nspeed_wall_0 = =speed_wall\ninfill
          ;SETTING_3 sparse_density = 50\nsupport_xy_distance = 2\nspeed_layer_0 = 50\
          ;SETTING_3 ninfill_overlap = 25\nwall_thickness = 1\nlayer_height_0 = 0.195\n
          ;SETTING_3 top_bottom_thickness = 0.6\nretraction_combing = noskin\naccelerati
          ;SETTING_3 on_wall = None\nspeed_print = 100\nmaterial_diameter = 1.75\ncool
          ;SETTING_3 fan_full_at_height = 1\nspeed_travel = =speed_print if magic_spirali
          ;SETTING_3 ze else 120\nretraction_speed = 30\ncool_min_layer_time = 20\nspee
          ;SETTING_3 d_infill = =speed_print\njerk_wall = 5\nretraction_hop = 0.5\nline
          ;SETTING_3 _width = 0.48\nretraction_extra_prime_amount = 0.4\nspeed_topbottom
          ;SETTING_3 = =speed_print / 2\nacceleration_enabled = False\nsupport_pattern
          ;SETTING_3 = concentric\njerk_enabled = False\ninfill_before_walls = False\nr
          ;SETTING_3 etraction_amount = 3\nadhesion_type = skirt\nsupport_enable = True
          ;SETTING_3 \nlayer_height = 0.2\ninfill_line_width = 1\nretraction_hop_enabled
          ;SETTING_3 = True\nmaterial_print_temperature = 205\n\n"}
            That is indeed the problem: Cura is not generating the comment saying how much filament is needed, that all other slicers (including the "old" Cura) generate. Also they have made the layer height setting more difficult to parse. So the only estimate that RRF is able to generate is the one based on file size.
            • Jackalundefined
              Jackal
              What are the comments RRF uses to calculate the estimates?
              I found that when I use Simplify3D to slice different parts of the model with different layer heights, the total layers shown is incorrect.
              I haven't check if this is caused by S3D or RRF, will look into the gcode tonight.
                burtoogle
                @dc42:
                But the web display doesn't even show an estimate based on file size. It shows n/a for all 3 estimation methods.
                  @burtoogle:
                  @dc42:
                  If it still shows that after printing a few layers (can you confirm?), that sounds like a bug. Please put a smallish gcode file that reproduces the problem somewhere where I can get it (e.g. Dropbox, Google drive, MS OneDrive etc.), suitable for either a delta printer with 280mm printable diameter or a Cartesian printer with 200x200mm print area.
                    burtoogle
                    Sorry, only just noticed your last reply, I will provide you with a file.
                    I have contacted the Cura devs re the lack of total filament used info in the current gcode and, yes, the current Cura no longer provides that info for non-ultimaker printers. I will work on putting that back in so I would like to know if you have any preferences in the format of the info (same as before, or different) and also I wonder about whether something different needs to be done for multiple extruders? For ultimaker printers, the current Cura outputs lines like this:
                    ;MATERIAL:3748
                    ;MATERIAL2:0
                    I assume those are mm not m!
                    Can the Duet just use that format? If so, I can get the same info output for non-ultimaker printers.
                      burtoogle
                      Here's a gcode file produced by cura 2.3.1
                      https://www.dropbox.com/s/w6ejx543qw1h65y/KX_ooze_retract_test_by_vector.gcode?dl=0
                        burtoogle
                        I have now modified Cura to output the total filament used in a similar fashion to how Cura 1.15 did and that appears to work as expected. What's interesting is that it also fixes the estimate based on file progress as well as the estimate based on filament usage so my guess is that when the filament usage estimate is broken, it also breaks the file usage estimate.
                        Anyway, if you add the following line into the head of the above example file, the file and filament estimates work OK. However, the layer time estimate is still broken.
                        ;Filament used: 0.173359m
                          burtoogle
                          Just letting you know that the next release of Cura (2.4?) should include the filament used comment in the style shown above.
                          • auserundefined
                            auser
                            Great work! I really missed print time estimate based on filament used in 2.3!
                            Thanks a lot!
