    Duet3D Y-Axis Motor turning in only one direction
    • Sureshotundefined
      Sureshot
      I am upgrading my Geeetech Rostock 301 and have installed a Duet3D V1.03 board. The Z and X Axis motors work correctly, however the Y-axis motor is acting strangely.
      Sometimes it will turn both clockwise and anti-clockwise when I send a G1 S1 Y50 command, but only for about a revolution before it reverses.
      Once this happens, it will only turn in one direction, if I send a positive or negative ammount.
      If I change the motor configuration, then the motor will reverse it's direction, once again it will only turn one way no matter what command it is sent.
      I have checked multiple cables, motors, and board connections - it only happens on the Y-axis.
      So far, it has never worked correctly.
      I am running the latest firmware:
      "RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03RC4 running on Duet WiFi 1.02 or later"
      Do I have a faulty board, or am I missing a setting or configuration?
      • Vetiundefined
        Veti
        change the drive mapping using https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
        and assign the y axis to the e1 motor.
        if it works then, there is something wrong with the y stepper.
        • Sureshotundefined
          Sureshot
          I tried your suggestion, the motor vibrates and I receive an error message:
          "Error: short-to-ground reported by driver(s) 3"
          I have identified the pairs of cables, and have tried reversing them in the connector, and it is the same result each time.
          I also switched back to using the Y-axis, and the motor will only turn one way.
          • Vetiundefined
            Veti
            driver 3 is E0 extruder. that would be another problem
            if it vibrates that would indicate a wiring problem.
            verify that you have the correct phases on that motor with a multimeter.
            • Sureshotundefined
              Sureshot
              My apologies. I connected the motor to E1, and it works correctly with the wiring as I originally connected it.
              It seems I have a faulty board.
              Any suggestions?
                dc42 administrators @Sureshot
                @sureshot said in Duet3D Y-Axis Motor turning in only one direction:
                Any suggestions?
                It does sound that your Y motor driver is faulty, and you should ask your supplier to replace the Duet. Assuming it's a genuine Duet, see https://www.duet3d.com/warranty.
