RRF Configurator & PT100 on Maestro
Firmware installation
    JRDM
    My uSD card died so I thought I'd try the RRF configurator to speed up setup.
    Heater 1 has a PT100 on it and I set up what I thought was the correct setup. RRFC spit out this line:
    M305 P1 X200 R2200
    It should have been:
    M305 P1 X200
    RRF seemed to get confused with the 'R2200' parameter. Once I removed 'R2200', the sensor worked fine.
    For the moment everything else seems fine.
    undefined 1 Reply Last reply 2 Jun 2019, 07:31 Reply Quote 1
      PaulHew
      The 'R2200' parameter is required for a Maestro.
      If it was another board like the Duet2 i think is R4700.
      This is my Hotend heater line for a E3D V6
      M305 P1 T100000 B4725 C7.060000e-8 R2200
      And my Bed is
      M305 P0 T98801 B4185 R2200
      Looks like you are missing some parameters, possibly
      undefined 1 Reply Last reply 2 Jun 2019, 07:36 Reply Quote 0
        dc42 administrators @JRDM
        @jrdm said in RRF Configurator & PT100 on Maestro:
        M305 P1 X200 R2200
        M305 P1 X200
        RRFC seemed to get confused with the 'R2200' parameter. Once I removed 'R2200', the sensor worked fine.
        Thanks for pointing this out, we'll get it fixed.
          dc42 administrators @PaulHew
          @paulhew said in RRF Configurator & PT100 on Maestro:
          Actually the R parameter is almost never needed. The cases when it is needed are:
          • When using a Duet 085 or a later Duet 06 with a thermistor, because the default for these boards is 1000 but later boards use a 4700 ohm series resistor;
          • When using a PT100 with a third-party MAX31865 interface board, and the reference resistor on that board is not 400 ohms.
            PaulHew
            @dc42 Learnt something again today!
            1 out of 5
