    Dual z motor leveling
    • yoyobob19undefined
      yoyobob19
      So Is there a way to invert the Z adjustment? when i run 2 motor z leveling the leadscrews turn in the oppsite direction. is there a way to invert it ? here is my current set up
      i have drivers 2 and 4 driving my z motors.
      M671 X20:400 Y200:200 S10 ; leadscrews at left and right of X axis
      M558 P8 H7 F200 T10000 I1 A10 S.005
      G30 P0 X20 Y200 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X400 Y200 Z-99999 S2 ; probe near a leadscrew and calibrate 2 mot
      M558 P8 H7 F1000 T60000 I1 A10
      thanks!!
      • Vetiundefined
        Veti
        try swapping the x coordinates
        M671 X400:20 Y200:200 S10 ; leadscrews at left and right of X axis
        • Vetiundefined
          Veti
          or swap the connectors of the 2 z motors
            As @Veti says. You must declare the coordinates of the motors in the same order in M671 as you declare the associated driver numbers in the Z parameter of M584.
