Do I need a new IR Probe?
    Synapsis
    I having on and off for no apparent reason the IR probe which not level correctly. As soon as I turn on I see that the reading is between 2 and up to 63 when this happens it fires to early and not near the bed. This happens even when I tried with the bed 12 cm down.
    Should I by a new one? I checked the wiring and all looks ok. When I turn it off it was working.
    undefined 1 Reply Last reply 2 Jun 2019, 17:02 Reply Quote 0
      dc42 administrators @Synapsis
      If this happens independently of how far away the sensor is form the bed, the most likely explanation is a bad crimp in the cable connecting the IR sensor to the Duet,
        Synapsis
        Thanks will try that even if they look good.
          Synapsis
          After checking the wires still the same problem. Was about to give up. I had put on the black glass bed a few days ago some blue tape for better adherence for fussy PLA,
          So I took it off to clean the bed. I tried the homing for no real reason but to my surprise it worked perfectly. Now the strange thing is the I was homing on the tape for a few days.
          Wonder why it decided it would home on the tape anymore. Important thing its solved.
          2 out of 4
