    Coloured vertical lines on PanelDue 7i
    PanelDue
    487
    • erikwundefined
      erikw
      Installed Paneldue and Duet2 wifi and at the beginning I had the screen running. Afther using RepRapFirmware Configuration Tool the screen was not functioning and just coloured vertical lines on the PanelDue. What wend wrong ?
        dc42 administrators @erikw
        Are you powering the Duet from USB power only? If so then there may be insufficient power from the USB port on your PC or laptop to power the Duet + PanelDue.
        erikwundefined 1 Reply Last reply Reply Quote 0
          A Former User
          Given the communication between the Duet and the PanelDue is serial it wouldn't affect the screen like you describe.
          How is it connecteded?
          • erikwundefined
            erikw
            Its conected with the laptop (usb) or direct 24v power supply, both dosnt work anymore
              You can try disconnecting the PanelDue from the Duet and applying USB power directly to the PanelDue. If you still get the vertical lines, try erasing and re-flashing the firmware.
              • erikwundefined
                erikw @dc42
                @dc42 Its conected with the laptop (usb) or direct 24v power supply, both dosnt work anymore
                  @erikw said in Coloured vertical lines on PanelDue 7i:
                  Does that mean you have tried powering the Duet by USB? I am suggesting that you try powering the PanelDue from its own USB connector, to see if there is an issue with power coming from the Duet.
                  • erikwundefined
                    erikw
                    Installed new firmware and is now running fine. Thanks !!
