    Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released
    Firmware installation
    11
    29
    4.7k
    • DocTruckerundefined
      DocTrucker
      Thanks for the continuing updates to the 1.x firmware. Will update later this evening.
        Tested it out last night on a 6 hour print. I even tried the Jerk policy of 1 to see if I could tell the difference. I wasn't sure what to look out for, but the print completed successfully at any rate. XY jerk of 700, PA of 0.045.
        • Alpenprinterundefined
          Alpenprinter
          Since updating to 2.03, I think, that there is a new issue.
          Within long prints, the display and the web interface twice got unresponsive about in the middle of a print (after around 5h).
          But the print was finished correctly. After finishing, the duet display (7´) and the web interface still show the bed and hotend temperature that where used during the print.
          The "STOP" button on the display reacts, but failed to connect to the duet board again.
          Power on/off fixes the problem.
          In the 2.03 RC the fault did not appear.
          zerspaner_gerdundefined 1 Reply Last reply Reply Quote 0
          • zerspaner_gerdundefined
            zerspaner_gerd @Alpenprinter
            @alpenprinter said in Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released:
            I also observed that!
            At first I thought only of wireless problems but also the PanelDue did not react anymore.
            I also had this in 2.03 RC, Final 2.03 I have just installed today.
            Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
            Alpenprinterundefined 1 Reply Last reply Reply Quote 0
              Alpenprinter @zerspaner_gerd
              What's the latest firmware version known to run stable?
              @zerspaner_gerd said in Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released:
                Phaedrux Moderator @Alpenprinter
                2.02 was the last stable release.
                What version of DWC and PanelDue firmware are you running?
                Alpenprinterundefined 2 Replies Last reply Reply Quote 0
                  Alpenprinter @Phaedrux
                  @phaedrux said in Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released:
                  Panel Due 1.20
                  DWC 2.0.0
                    I downgraded to 2.02 and all is running fine again. I kept DWC 2.0.0, no problem with this.
                      A Former User
                      Not sure if this is a bug or a feature/limitation, but if using M918 P1 E4 to enable a 12864 display the PanelDue serial port does not get the {"beep_freq":7000,"beep_length":2000} message even if the serial port is set up with M575 P1 B57600 S0. Which seems odd as {"message":"HELLO WORLD"} from M117 Hello World is sent to the PanelDue port even with the 12864 display enabled, removing the 12864 from the config results in the beep messages being sent to the PanelDue port without any other changes made.
                      (Also M918 P0 is rejected as unkown display, so only way is to reboot. Same behavior in v3 in both cases)
                        @bearer said in Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released:
                        That's the way it is written. But I can make both the 12864 and PanelDue bleep in the next build.
                        I didn't anticipate any requirement to disable the 12864 display once it has been enabled.
                          A Former User @dc42
                          @dc42 said in Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released:
                          I just tried as the g-code wiki listed Pn Directly-connected display type: P0 = none (default) which the firmware rejected, I don't see the need to un-configure it, but maybe the wiki was a bit unclear in that respect.
                          As for the beep with and without 12864, I'm okay either way, was just surprised that there was a difference between M117 and M300 without any indication of it being by design or not. If supporting efforts like https://forum.duet3d.com/topic/10720/duet3d-monitor-adding-a-big-status-light-to-your-printer is a priority I can see having the protocol as complete as possible even if not used with a PanelDue would be beneficial.
                            I have removed the P0 option from the description in the GCode wiki.
                            That's why I changed the code yesterday to send the beep to both displays. This change is already in the RRF3 beta build and it will also be in RRF 2.03.1 when I release that.
                              A Former User
                              ☝ Awesome!
                              • Yakanduundefined
                                Yakandu
                                Another "maybe" bug.
                                I have duet 3d wifi on a delta printer, with the new function "M665 L260.0:260.0:260.0" to give the firmware the diagonal rod offsets, if I leave them the same as in the example everything works fine, now, if I change the values after calibrating with the hexagon I get (and thats what I got when I was running Marlin) L267.3:267.1:266.9, a 0.2mm difference between the rod pairs, my printer misses steps while homing (the second bump, but not in the first one) and misses steps while calibrating and printing.
                                I, then, proceed to experiment, the greater the difference, the more steps it misses.
                                So I'm now back to the L267.1 (the mean of the tree pairs) until this is fixed, it happens too to others in my printing community.
                                Here I provide you my homedelta, config override and config in case you want to check them out.
                                2_1561532460509_homedelta.g 1_1561532460509_config-override.g 0_1561532460509_config.g
                                  Thanks for your report - I've added it to my list to investigate.
                                  The recommended way to handle scaling errors is not to adjust the rod lengths but to use M579.
                                  • kraegarundefined
                                    kraegar
                                    Two things I've seen so far.
                                    M280 to turn a servo in a macro sometimes doesn't run until the end of the macro, after any other moves etc. Putting M400's before/after fixes it. (It's not every macro that's affected, some run as expected, others don't turn the servo until the end, no rhyme or reason I can spot)
                                    M116 behavior changed slightly, still looking at this. Probably only affects testing, but I'm not sure. Previously if no temp was set I could switch through tools and the M116 did nothing. Now it stalls and waits on something. I tried setting the temp to 30c on each tool. It does bring the temp up to 30c but never proceeds. I may need to set a standby temp for each tool and retest, still looking into it. Commenting out the M116 lets the swaps proceed as normal.
                                    One other thing that may be as intended, but surprised me. I thought having a minima for Z set to -0.1 wouldn't affect anything other than letting me move down "into the bed" past Z=0. I homed X/Y/Z, then did a mesh probe and the mesh showed entirely "under the bed". Changing the minima to Z0 resolved that. It's likely I just misunderstood this functionality, but figured I'd note it. (the documentation seems to indicate this is expected behavior)
                                      dc42 administrators @kraegar
                                      @kraegar said in Firmware 2.03 (Duet 2) and 1.24 (Duet 06/085) released:
                                      Can you construct a macro that reproduces this reliably?
                                      There has been no intentional change to M116. Can you reproduce it, preferably in a standalone macro?
                                      No, it's not intentional behaviour. The only way that the M208 Zmin setting should affect the Z=0 position is if you use a Zmin homing switch, and after the G1 H1 Z-nnn move in homez.g you don't have a G92 Z command to set the actual Z position.
                                      • kraegarundefined
                                        kraegar
                                        The method for my testing is simply a macro that loops through tool changes, "Test Tools Pickup".
                                        So it loops through each tool in order. I'm not going to cover them all, but here's the summary so far:
                                        The first issue hit is with M280 in tfree0.g (tpost0.g completes with no issue with either M116 or M280, weirdly). If I wrap M400's around the M280, tfree0.g completes fine.
                                        The next issue happens during tpost1.g where it stalls out on the M116 line. I tried setting all of the active & standby temps to 30c before testing, and it still hangs on the M116 on tool 1.
                                        The macros in question are here (quickly cleaned up for readability):
                                        https://www.dropbox.com/sh/oo610lsff1g3n85/AAA6O112JlaB--WkmdfMJla8a?dl=0
                                        Here are screenshots of the difference between M208 Z-0.2 vs. M208 Z0 for Zmin. No other changes. Steps to reproduce:
                                        Home X/Y, Home Z using a microswitch on the X carriage. Run G29.
                                        Z-0.1:
                                        https://i.imgur.com/R7qS1ro.png
                                        Z0:
                                        https://i.imgur.com/eWa53j6.png
                                        • kraegarundefined
                                          kraegar
                                          This post is deleted!
                                          • kraegarundefined
                                            kraegar
                                            Another one. Not sure if it's any gcode, or just this file. 4 tool print. First 3 go fine. 4th tool it picks up, runs the cleaning routing, then goes to print, and the Z height drops to -3.30mm.
                                            Here's the section of gcode:
                                            G1 E24.67887 F2400.00000
                                            G92 E0
                                            G1 Z0.600 F7800.000
                                            G91
                                            G1 Z5 E-2 F1800
                                            G90
                                            T3
                                            G92 E0
                                            G1 E-2.00000 F2400.00000
                                            G92 E0
                                            G1 X150.900 Y99.100 F7800.000
                                            G1 Z0.350
                                            G1 E2.00000 F2400.00000
                                            G1 F1800
                                            G1 X150.900 Y85.900 E2.66248
                                            Since it's setting the working height to 0.350 in the gcode, I can't for the life of me figure why it's diving to -3.30mm. If it were an offset issue, it would display it was at the correct Z of 0.350
                                            Dropping to 2.02 resolved this issue. (Though in 2.02 it's not running T0 to grab that tool at the start of my print, need to figure that out next I guess since I know others are on 2.02)
                                            I can post my offset files and tool change scripts if that helps.
