    dual z axis homing problem
    826
    • Marco Bonaundefined
      Marco Bona
      I followed the instructions in this link :https://forum.e3d-online.com/threads/bigbox-dual-optical-z-max-endstops.2675/
      • SIamundefined
        SIam
        and this macro does work ? or not ?
        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
        Duet WiFi 1.02 or later + DueX5
        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
        Duet WiFi Server: 1.26
        Duet Web Control 3.4.0beta4 (2021-09-27)
          deckingman @Marco Bona
          @marco-bona Which firmware version are you using? Note that M574 which you are using to map end stops was introduced in a beta version but later withdrawn because it had some adverse effects. I believe it works in RRF 3 beta but not that latest stable RRF2. There was another recent thread about it here https://forum.duet3d.com/topic/10968/problem-with-m574
            Marco Bona
            I'm using the latest firmware 2.03.
            Before it worked, then after the update it started to give problems.
            So the problem is just the limit switch mapping?
              dc42 administrators @Marco Bona
              @marco-bona said in dual z axis homing problem:
              Yes. In these commands:
              M574 Z2 C8 S0
              M574 U2 C9 S0
              the C parameters will be ignored. So the Z axis will use the Z endstop input, and the U axis will use the E0 endstop input. If that's a problem then you will need to install the RRF 3 beta firmware and read https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview.
                Marco Bona
                The z and e0 inputs are already occupied, I try to install rrf3 and remap the limit switches.
                Thanks
                  Thanks
                  What are they occupied with?
                    Marco Bona
                    E0 and E1 for laser filament monitor, X and Y for X-Y limit switches and Z for an overtravel switch
                      You could connect the filament monitors to the two endstop inputs on the CONN_LCD connector.
                        Marco Bona
                        One is already occupied with the emergency button.
                        I have updated to RRF3 and the limit switches work correctly during Z homing
