Layer height runs
  • https://vimeo.com/329770517
    Why does it do it
  • Moderator
    @steffen We need the GCode file that causes this behavior to say for sure.
    But first shot in the dark that comes to my mind is: are you using variable layer height? Also which slicer are you using (but that would be answered by the GCode most probably)?
  • layer 0,200
    Simplify3D-4.1.2
    It has just come by itself
    A print of about 5 min
    It's on every print it does
  • Moderator
    @steffen I know that S3D creates some weird GCodes that makes it sometimes hard for RRF to figure out which layer it actually is right now.
    Again, uploading the GCode file (or any GCode file where this happens) would be helpful.
  • Moderator
    @steffen At least there is nothing obviously strange with that GCode at first sight. You have a Z-hop of 0.4mm and it starts at 0.172mm for the first layer and increments in 0.2mm steps from there.
    Also relevant: Firmware and DWC versions.
    Maybe @dc42 has any idea on this one?
    EDIT: I checked the file again. The following command confuses the FileInfoParser:
    G1 Z-275 F40 S1; Move slowly to Z axis endstop once more (second pass)
    can you maybe move your start codes into a macro file and just call M98 Pstart_macro.g?
    I commented out this line and now the estimation works as expected.
  • Moderator
    G1 Z5 F1800
    G90
    G1 X0 Y5 Z0.2 F3000 ; get ready to prime
    Any and all of those Z moves will confuse it.
  • Moderator
    @phaedrux said in Layer height runs:
    G1 Z5 F1800
    G90
    Actually, the first one will be ignored because it is in relative movement mode. But you are right about the last one (which I did miss because it coincidentally is close enough to the real first layer's Z height so that there is no real confusion).
  • Here's my start script, something that's not necessary
    G28 ; home all axes
    G91
    G1 Z5 F1800
    G90
    G92 E0 ; reset extrusion distance
    G1 X250 E20 F600 ; prime nozzle
  • What do you have in homeall.g ?
    Because all of this
    G91
    G1 Z5 F1800
    G90
    should be in there. It gets executed with G28
  • ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool on Tue Jun 06 2017 22:17:43 GMT+0200 (Rom, sommertid)
    ; Relative positioning
    G91
    ; Lift Z
    G1 Z5 F4000 S2
    ; Course home X and Y
    G1 X-305 Y-305 F1800 S1
    ; Move away from the endstops
    G1 X5 Y5 F6000 S2
    ; Fine home X and Y
    G1 X-305 Y-305 F360 S1
    ; Absolute positioning
    G90
    G1 Z-275 F800 S1
    G91
    G1 Z5 F1800 S2
    G90
    ;mowe slowly to z axis endstop once more (secone pass)
    G1 Z-275 F360 S1
    ; Go to first bed probe point and home Z
    ;G1 X15 Y15 F4000
    ;G30
    ; Uncomment the following line to lift the nozzle after probing
    ;G1 Z5 F100
  • One of my friends sent this file and when I print it is okay
    I can't see what's wrong
    0_1555150796397_infinityheart.gcode
  • By the way, it's a machine similar
  • Moderator
    We've explained why it's doing it.
    You have homing moves in your start gcode in the slicer that shouldn't be there.
    Let's compare the file your friend has to yours.
    His
    G90
    M83
    M106 S0
    M140 S80
    M190 S80
    M104 S240 T0
    M109 S240 T0
    G28 ; home all axes
    Yours
    G90
    M82
    M106 S255
    G4 P500
    M106 S128
    M140 S80
    M190 S80
    M104 S247 T0
    M109 S247 T0
    G28 ; home all axes
    G91
    G1 Z5 F1800
    G90
    Do you see the difference?
    You need to remove this from your start gcode in the slicer.
    G91
    G1 Z5 F1800
    G90
  • Yes it makes sense Thank you
