    Pressure sensor connection
    • Marco71undefined
      Marco71
      Hi guys, sorry silly question, I recently bought a WiFi Duet2 1.04, everything works but I have a doubt about the connection of a pressure sensor that sticks to the nozzle, I wanted to know before doing damage if I could connect it and possibly how to set it
      Thank you
        Do you have any documentation for that sensor and the interface board? is it compatible with 3.3V power?
        • Vetiundefined
          Veti
          it is basicall just a simple endstop.
          you dont need to board and can connect the sensor directly to the duet on signal and ground on the probe endstop connector.
          it should be M558 P5 I1
          • Pillcciaundefined
            Pillccia
            Hello
            I would like to know if you have solved the problem of the zprob, with the pressure sensor.
            I only get the first touch, then error!
            does not reopen the contact
              Phaedrux Moderator @Pillccia
              @pillccia said in Pressure sensor connection:
              Hello
              We would need quite a bit more detailed information. Perhaps best to start a new thread.
