    PanelDue 7i
    PanelDue
    • Iamturbo1978
      Iamturbo1978 last edited by
      Hello everyone,
      I'm looking for information on in the integrated PanelDue 7i display. I found the basic dimensions, but it doesn't give the SD card placement. Where can I find a more detailed diagram?
      Also, what are the 2 buttons for on the front of the PCB? Are they for just the display, or do they control the Duet?
      Thanks
        I don't have a drawing, but I measured the SD card placement and included an appropriate cutout in my printable PanelDue enclosure design, which you can find on thingiverse.
        The buttons are Erase and Reset. Erase is needed when you want to install new firmware.
        Iamturbo1978 1 Reply Last reply Reply Quote 0
        • Iamturbo1978
          Iamturbo1978 @dc42 last edited by
          @dc42 thank you for the reply. I will check it out tonight. Thank you for that.
          Do the buttons only reset and erase the display, or do they reset and erase the Duet? Just trying to decide if access to them is required for standard use.
          nhof 1 Reply Last reply Reply Quote 0
          • nhof
            nhof @Iamturbo1978 last edited by
            @iamturbo1978 The erase and reset buttons only apply to the screen. The duet has separate erase/reset buttons.
            The buttons are only used when updating the screen firmware, so you shouldn't need to access them very often.
            • Iamturbo1978
              Iamturbo1978 @nhof last edited by
              @nhof cool.. thank you
