    RepRapFirmware 3.0
    176
    30.6k
    • clearlynotstefundefined
      clearlynotstef
      Ok, I've updated to 3.0 to run my weird cnc contraption. I'm a bit stuck on how to set it up. I have two Y motors and endstops, z, x and e (which is actually a tangential cutter but rotates based on E moves). I have Y hooked up to the Z driver and mapped as M584 Y0 Z1 X2 E3. Does this make sense given I have two endstops and motors on that axis? Should I be defining the second y motor as its own axis to use an second endstop? What should my M574 look like?
      As always, appreciate any help!
      • A Former User?
        A Former User @clearlynotstef
        @clearlynotstef said in RepRapFirmware 3.0:
        Seems off me? "Z driver" should be driver number 2, so you should probably have Y2 in there. Are you connecting both motors to the same driver output? If not you need something like Y2:1 or Y2 U1 (if the two Y motors are connected to the Y and Z drivers which ar drivers 1 and 2 respectively) ... or so i think at least.
        If you clarify that bit I'm sure someone can help you with the M574
        clearlynotstefundefined 1 Reply Last reply Reply Quote 0
          clearlynotstef @A Former User
          @bearer that's what I guess I'm trying to figure out. I currently have both Y motors hooked up to driver 0 (typically used for Z) so I can drive them off of the same driver without merging cables. This means I can't drive one without driving the other, which I guess means the best case scenario with two end stops is smashing one side into the endstop until the other catches up and hits the other endstop. Given I have an extra driver still, maybe I should drive each y motor off its own driver with it's own endstop, but still define both drivers as being the y axis? Not sure how to define the motors and end stops in either scenario on 3.0!
          • A Former User?
            Which board are you using?
              @bearer duet 2 Wi-Fi
              • A Former User?
                A Former User
                Then maybe you should wait for someone else to tell you that driver 0 is not the one labeled for Z as you seem to ignore me telling you that ... because you're not going to have much success until you do.
                  @bearer... I'm not disagreeing with you, I thought you were proposing a different way of achieving this setup, not trying to correct the way I currently have it setup, it wasn't particularly clear. "Should be driver 2" sounds like a suggestion, not a fact. One would think the drivers would be numbered sequentially from one side of the board to the other.
                    dc42 administrators @clearlynotstef
                    You would think that; but they are not. The order is 2 1 0 3 4.
                      clearlynotstef @dc42
                      @dc42 good to know. I think I'm going to abandon running them off one stepper anyway (unless there's a way to use two endstops that makes sense), so I'll have two drivers driving two motors on the y axis, each with an endstop. Let's say y driver and e1 driver. Does any sample g code exist for setting these up with their own end stops on 3.0 beta?
                        No, but it's fairly straightforward with RepRapFirmware 3. Use M584 in config.g (before any M350 or M906 commands) to define your Y motors:
                        M584 X0 Y1:4 Z2 E3
                        and use M574 to define the endstop switches:
                        M574 X1 S1 P"xstop" ; X min active high endstop switch
                        M574 Y1 S1 P"ystop,e1stop" ; Y min active high endstop switches
                        M574 Z1 S1 P"zstop" ; Z min active high endstop switch
                        Omit the M574 Z command if you use a Z probe to home Z.
                        clearlynotstefundefined 2 Replies Last reply Reply Quote 0
                          @dc42 thanks! While I've got you. Let's say I do want to use the z driver for both Y motors, obviously I could only move them both or neither, but could I configure it with two end stops such that it isn't home until they're both pressed?
                          • A Former User?
                            Wire switches in series or parallel depending on normally closed or normally open; but the first motor won't stop until both swtiches are active so you will have collisions.
                              I'm stuck. I've used your gcode above, omitting the z line as I'm using a probe.
                              M584 X0 Y1:4 Z2 E3
                              M574 X1 S0 P"xstop" ; X min active high endstop switch
                              M574 Y1 S0 P"ystop,e1stop" ; Y min active high endstop switches
                              I've switched the S1 to S0 (but tried it both ways).
                              The machine properties window lists X, Y, Z, E0 for endstops. X works as expected. The Y axis (as a reminder, two motors and two end stops) does not. The respective indicators on the board light up when the endstop is triggered, but machine properties never switches to Yes. Interestingly, if I remove one of "ystop" or "e1stop" from the second M574 command, machine properties switches to Yes for the Y axis upon pressing the endstop that remains (Y axis turns to Yes if I remove e1stop from the command and press the ystop endstop, or if I remove ystop from the command and press the E1 endstop), but if I keep both, Y never turns to Yes if I press either or both endstops.
                              1. any ideas?
                              2. is it the even desired behavior that Y turns to yes in the machine properties window if any of the endstops belonging to that axis are triggered (or both?) Why is E0 showing as an endstop in that list?
                              Thanks as always!
                              • denkeundefined
                                denke
                                @dc42 Would you consider adding a new gcode to "load default pin assignment" and not load it by default?
                                This way if someone wants "compat mode" because has a fairly defualt use case he/she can put it somewhere in the top of config.g, if not then the user can create a custom pinout for him/herself without the need to deassign pins from their default function first.
                                I think it would create a clearer case.
                                  M584 X0 Y1:4 Z2 E3
                                  1. any ideas?
                                  Thanks as always!
                                  Are you definitely running RepRapFirmware 3 beta?
                                    dc42 administrators @dc42
                                    This topic is getting long and hard to navigate, so I am locking it and creating a new one.
