topic_solved Duet Web Control Scrolling Issue
Scroll down almost immediately reverses. Searched and found only posts related to this problem on an earlier version.
Running Chrome on PC, Windows10
This is what I have:
RepRapFirmware for Duet 2 WiFi/Ethernet
WiFi Server Version: 1.22
Web Interface Version: 1.22.6Note - everything was fine until the problem started last evening. Any help appreciated.
@danl I had the same issue today. I resolved it by closing out the tab, shutting down the browser, and reloading. No idea why it occurred- and it was only happening on one device
Tried that....still happens. Getting frustrated....
There is an item in the user interface settings of DWC that you can change to fix this. I can't remember the exact name, it's something like always show headings.
Only some versions of some browsers have this issue. So a browser update can make it go away or return.
Ahhh... thank you, thank you...
Headings > General > UNCHECK Always show info area and main menu...
Problem resolved. -
Thank you, finally!
