    Duet Ethernet config running on a Duet Maestro
    Firmware installation
    • singhm29
      singhm29 last edited by
      Hey,
      A community member was kind enough to provide his Duet Ethernet files that he used with his setup but unfortunately, I have a Maestro. Would I need to adjust many of the files found in the sys directory to get it running on the Maestro such as pin assignments etc? I recognize that certain features like stall detection that he might have enabled will not work for the Maestro.
      Thanks!
      • Veti
        Veti last edited by
        max current for the stepper is lower.
        the resistor for thermistors is 2200 instead of 4700 (just delete the R part completly)
        the maestro supports stealthchop2, so you might want to tune those settings.
        • singhm29
          Thanks for the insights!
