    G28 Z Error
    • DanLundefined
      DanL
      Have homex, homey and homeall working perfectly, and homez works but delivers a G28Z error.
      When I individually home x and y, then z, the z will home but the error message pops. Searched and tried some different parameters, but just can't figure this out.
      I did not uncomment the last lines of Z probing because G30 does "lift Z" as it finishes.
      homey is same format as homex:
      ; homex.g
      ; called to home the X axis
      G91 ; relative positioning
      G1 Z3 F1800 S2 ; lift Z relative to current position
      M913 X70 ; current to 70%
      G1 S1 X305 F3000 ; move quickly to X axis endstop and stop there (first pass)
      G1 X-5 F6000 ; go back a few mm
      G1 S1 X305 F360 ; move slowly to X axis endstop once more (second pass)
      M913 X100 ; current to 100%
      G1 Z-3 F1800 S2 ; lower Z again
      G90 ; absolute positioning
      G1 X290
      ; homeall.g
      ; called to home all axes
      M913 X70 Y70 Z60 ; reduce stepper currents
      G1 S1 X305 Y305 F3000 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 X-5 Y-5 F1800 ; go back a few mm
      G1 S1 X305 Y305 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 X150 Y150 F6000 ; go to first bed probe point and home Z
      M913 X100 Y100 Z100 ; increase current to 100%
      ;G91 ; relative positioning
      ;G1 S2 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      .; homez.g
      ; called to home the Z axis
      G1 Z3 F1800 S2 ; lower bed relative to current position
      G4 P1000 ; ensure time for bed drop
      M913 Z60 ; reduce current to 60%
      G1 X150 Y150 F6000 ; go to first probe point
      M913 Z100 ; increase current to 100%
      ;G1 S2 Z3 F1800 ; lift Z relative to current position
      DanL
        What is the error?
        Does it still happen if you remove the G4 P1000 pause? That shouldn't be necessary, it should wait for the Z move to complete before moving on to the XY move.
        • DanLundefined
          DanL
          The error message...pink box... just reads "G28 Z Error: Bad command"
          Is there more info somewhere else?
          I'll remove the pause.
          Thanks.
          DanL
            Phaedrux Moderator @DanL
            @danl said in G28 Z Error:
            .; homez.g
            Just noticed that there is a period before the semicolon. Does that exist in your macro file as well?
            • DanLundefined
              DanL
              yep...just looked. Geez, this stuff is touchy.
              I'll drop the G4 and the period and test in about 5 minutes.
              Thanks. Wow...really great catch.
              DanL
              • DanLundefined
                DanL
                Solved....whoa...just one little dot.
                Thank you.
                DanL
