    Ext Fan not going on at temp
    • Andy Cohenundefined
      Andy Cohen
      Setting up a new install and the extruder fan set to the thermostat is not turning on at the set temp. The fan tests show the fans work OK. Did I set it incorrect in the config??? It's P1... Here's the Gcode:
      M106 P0 S0 I0 F500 H-1
      M106 P1 S1 I0 F500 H1:2 T45
        That looks like it should work.
        Does the fan work at all? If you change it to be M106 P1 S1 I0 F500 H-1 it should turn on at full power.
