    Error in generated ressurect.g file
    • iratecrayons
      iratecrayons last edited by iratecrayons
      I had my first power failure today, and was able to get recovery working with a little bit of effort. I noticed that the generated ressurect.g has a small error in it where it didn't put quotations around the file name when calling M23, so on resume it failed to find the file until I renamed it. At least I think it is for this reason.
      ; File "Tube 1 (PLA).gcode" resume print after power failure at 2019-04-20 19:34
      M140 P0 S60.0
      G10 P0 S200 R200
      T0 P0
      G29 S1
      G92 X146.044 Y181.025 Z140.000
      M98 Presurrect-prologue.g
      M106 P0 S0.00
      M106 P2 S1.00
      M106 S1.00
      M116
      M290 S0.080
      G92 E0.00000
      M83
      M23 Tube 1 (PLA).gcode
      M26 S11969350 P1.243
      G0 F6000 Z142.000
      G0 F6000 X146.044 Y181.025
      G0 F6000 Z140.000
      G1 F6000.0
      M24
      The result of this was that it tried to load "Tube 1 .gcode" dropping the filename at the '(' character.
      Additionally the "M290 S0.080" had an additive effect (as it would normally), so upon re-running M916 after renaming the file it finally succeeded but left a bit of a gap at the first layer until I fixed the stepping, it might be better to use "M290 S0.080 R1" in this case.
      • iratecrayons
        And, before I forget. Last released firmware here.
        Firmware Name: RepRapFirmware for Duet 2 Maestro
        Firmware Electronics: Duet Maestro 1.0
        Web Interface Version: 1.22.6
        Web Interface by Christian Hammacher
        Licensed under the terms of the GPL v3
          Thanks for pointing these out. I have corrected the source code, so they will be fixed in the next release. It's R0 that needed to be added to the M290 command to set babystepping absolutely, not R1.
          M23 usually works without quotation marks around the file name, but perhaps not when the filename includes space characters.
          • iratecrayons
            You are absolutely right, R0 not R1! Sorry about that.
            Thanks though for the quick response.
