M574 ignores X configuration on my huxley duo?
  • I've had good prints out of my RepRap Pro Huxley Duo many times - It was acting a bit weird when sending some commands via Pronterface so I decided Updating the firmware and corresponding SD Image was a good course of action. It would appear I should have lived with the minor gremlins as now I cannot get the X-axis to home using the IR Z-probe that came with it.
    when I would try to home x after the new firmware flash it would move the hotend ~5mm left then stop - then I changed S1 for S2 in the homex.g and now it moves in the other (correct) direction towards the little tab that sets off the IR Z-probe...but it doesn't stop above it - just rams into the side and keeps pushing the stepper into the side.
    I've not changed the physical setup or knocked the machine or probe about after having it print really lovely jobs.
    M574 ignores the change to change X0 to X2 - seems to be ignoring the config.g file?
    If I posted my Config.g and homex and homeall would it help?
    any help appreciated
  • To help with this problem a bit (I've been helping out in #reprap on freenode)
    This is the printer
    This is the latest complete SD image for the older firmware
    EDIT:
    Here's the config.g and homex.g
    CONFIG:
    ; Configuration file for RepRap Huxley Duo
    ; RepRapPro Ltd
    ; Copy this file to config.g if you have an Huxley Duo
    ; If you are updating a config.g that you already have you
    ; may wish to go through it and this file checking what you
    ; want to keep from your old file.
    ; For G-code definitions, see http://reprap.org/wiki/G-code
    M564 H0
    M574 X2
    M111 S0                             ; Debug off
    M550 PRepRapPro Huxley Duo          ; Machine name (can be anything you like). With DHCP enabled connect to (example) http://reprapprohuxleyduo (machine name with no spaces).
    M551 Preprap                        ; Machine password (currently not used)
    M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x14 ; MAC Address
    ;M552 P0.0.0.0                       ; Un-comment for DHCPM552 S1 P0.0.0.0                  ; IP address, comment for DHCP
    M553 P255.255.255.0                 ; Netmask
    M554 P192.168.1.1                   ; Gateway, comment for DHCP
    M555 P2                             ; Set output to look like Marlin
    G21                                 ; Work in millimetres
    G90                                 ; Send absolute corrdinates...
    M83                                 ; ...but relative extruder moves
    M906 X700 Y700 Z600 E800            ; Set motor currents (mA)
    M305 P0 R4700 T100000               ; Set the heated bed thermistor resistance at 25C, series resistor to 4K7
    M305 P1 R4700                       ; Set the hot end thermistor series resistor to 4K7
    M569 P0 S1                          ; Reverse the X motor
    M569 P3 S0                          ; Reverse the extruder motor (T0)
    M569 P4 S0                          ; Reverse the extruder motor (T1)
    M92 E660                            ; Set extruder steps per mm
    M558 P2                             ; Use a modulated Z probe
    G31 Z0.8 P600                       ; Set the probe height and threshold (deliberately too high to avoid bed crashes on initial setup)
    M556 S45 X0 Y0 Z0                   ; Put your axis compensation here
    M201 X750 Y750 Z15 E750             ; Accelerations (mm/s^2)
    M203 X15000 Y15000 Z300 E3600       ; Maximum speeds (mm/min)
    M566 X200 Y200 Z30 E20              ; Minimum speeds mm/minute
    M563 P0 D0 H1                       ; Define tool 0
    G10 P0 S-273 R-273                  ; Set tool 0 operating and standby temperatures
    ;M563 P1 D1 H2                       ; Define tool 1, uncomment if you have a dual colour upgrade
    ;G10 P1 X19 S-273 R-273              ; Set tool 1 operating and standby temperatures, uncomment if you have a dual colour upgrade
    HOMEX
    M574 X2
    G91               ; set movement to relative mode
    G1 Z5 F200        ; move z up 5mm
    G90               ; set movement to absolute mode
    M558 P1           ; set probe to unmodulated mode
    G1 X-140 F2000 H2 ; home X
    G92 X0            ; set position to X=0
    G1 X3 F200        ; move axis away from X=0
    G1 X-5 F200 H2    ; home again, slower
    G1 X0 F2000       ; ADJUST the X value to put the nozzle on the edge of the bed
    M558 P2           ; set probe to modulated mode
    G1 Z-5 F200       ; move Z down 5mm
  • This post is deleted!
  • Oh right.
    @Mdev if you can verify the following:
    Running:
    M574 X2
    M574
    returns:
    Endstop configuration: X: high end active high switch, Y: low end active high switch, Z: low end active high switch
  • @duckle said in M574 ignores X configuration on my huxley duo?:
    M574 X2
    M574
    Exactly that yes.
    AFAIR the Huxley Duo uses the IR sensor for X homing. Therefore the command you need is either M574 X1 S2 or M574 X2 S2 depending on whether the homing tab is at the low-X or high-X end of the axis.
  • @dc42
    I added that command via the DWC Gcode Console and it worked - worked a treat.
    So I then added it to the config.g and re-ran the x homing command and it didn't work - rammed into the side.
    Checked what the reply to M574 was and it now says
    M574
    Endstop configuration: X: low end Z probe, Y: low end active high switch, Z: low end active high switch,
    This is good...but it isn't working. with this as the reply to M574 and I run the x homing command it just rams the side - doesn't even hesitate over the homing tab.
    I then popped it back into the Gcode console and ran the x axis homing command and now it doesn't work at all - checked the wiring...all good.
    What am I doing wrong?
    Check that with the sensor over the homing tab, the sensor consistently reads as triggered. You may need to stick a piece of white card or tape over the homing tab.
    Also check what mode the sensor it in and what the trigger value (G31 P parameter) is. AFAIR, RepRapPro sometimes changed the probe mode (M558 P parameter) from 2 to 1 during X homing. I don't know why they did that.
