Duex5 drivers dont appear to be applying full current...
  • build: 300x300x350 CoreXY, Duet + Duex 5 + PanelDUE
    duet and Duex connected by standard 30 pin, plus a 4" jumper main power wire to connect the + and - primary power blocks.
    So the other day i noticed something was just 'not right' with my z axis, which is a triple screw, and was driven by drivers 7 8 9 on duex5
    and the x y and E were driven by the stock drivers on the duet.
    x y and e were moving fine, no problems, for sure had no issues with torque, but i noticed that the z was missing steps, not holding torque, and i came to realize that just lightly pressing my finger on the screws, even when active was enough to halt movement, or cause movement when it was holding.
    moved the z axis motors to the DUET X Y Z drivers, and now my Z axis is primo, at 1.5A has enough force that i fear for the safety of my hot end, but, now my X Y axis are useless and struggle to even home when driven off drivers 8/9
    wondering if there was an issue getting power down that far i moved to driver
    but i am at a loss as to why there is no power on the duex drivers...
    config.g driver settings
    M569 P0 S0 ; z1
    M569 P1 S0 ; z2
    M569 P2 S0 ; z3
    M569 P3 S1 ; E1
    M569 P5 S0 ; X
    M569 P6 S0 ; Y
    M584 X5 Y6 Z0:1:2 ; x, y and Z definitiions
    M350 X16 Y16 E16 Z16 I0 ; Configure microstepping with interpolation
    M92 X80.00 Y80.00 Z400.00 E415 ; Set steps per mm
    M566 X900.00 Y900.00 Z10.00 E1200.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z400.00 E6000.00 ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z800.00 E1500.00 ; Set accelerations (mm/s^2)
    M906 X1000.00 Y1000.00 Z1700.00 E340.00 I60 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M122 output:
    4/21/2019, 8:09:50 PM: M122: === Diagnostics ===
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03beta2 running on Duet WiFi 1.02 or later + DueX5
    Board ID: 08DGM-917DA-G4MS4-6JTDA-3S06S-T8ZHA
    Used output buffers: 3 of 20 (16 max)
    Static ram: 25532
    Dynamic ram: 91736 of which 440 recycled
    Exception stack ram used: 508
    Never used ram: 12856
    Tasks: NETWORK(ready,560) HEAT(blocked,1236) MAIN(running,3848) IDLE(ready,196)
    Owned mutexes:
    Last reset 07:18:13 ago, cause: software
    Last software reset at 2019-04-21 12:51, reason: User, spinning module GCodes, available RAM 12880 bytes (slot 0)
    Error status: 0
    Free file entries: 10
    MCU temperature: min 35.9, current 36.3, max 36.6
    Supply voltage: min 24.3, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
    Driver 5: standstill, SG min/max not available
    Driver 6: standstill, SG min/max not available
    Driver 7: standstill, SG min/max not available
    Driver 8: standstill, SG min/max not available
    Driver 9: standstill, SG min/max not available
    Date/time: 2019-04-21 20:09:47
    Slowest loop: 5.93ms; fastest: 0.08ms
    I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
    Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms, Underruns: 0, 0
    Scheduled moves: 40, completed moves: 40
    Bed compensation in use: none
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.49ms; fastest: 0.08ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      Failed messages: pending 0, notready 0, noresp 1
      WiFi firmware version 1.23beta1
    Go to the GCodes wiki page, look up the entry for M584, and read the bit that starts with "Very important!". Acting on that will solve the problem.
  • @dc42 said in Duex5 drivers dont appear to be applying full current...:
    M584
    Roger! fixed! so my failure to explicitly define E in the M584 basically caused an incomplete build of the motor definitiions, for lack of a better description thus things were just not 'right'
    The reason was that your E motor current setting was being applied to those drivers, because they were configured as both extruder motor and axis motor drivers.
