    Y baby step insted of Z baby step on display
    424
    • benkue
      benkue last edited by
      is there an option to chance the axis in the macro ("z baby step") on LCD.
      I use a complete different System for my movements.
      My Z controlls an belt any my X and Y prints on an angle on the Z Belt. So Y would be my Z and the height of an object while printing.
      Thanks and best regards,
      Ben
        Is this a White Knight or similar printer?
        Currently the PanelDue firmware only supports baby stepping the Z axis. If you can compile it from source code yourself, it would be simple to change it to use the Y axis instead.
        • benkue
          @dc42 said in Y baby step insted of Z baby step on display:
          White Knight
          Yes, its the same System like White Knight 3D-Printer.
          I Think i have found it in sourcefile UserInterface.cpp
          0_1556179668123_2019-04-25 10_07_12-PanelDue - PanelDue_src_UserInterface.cpp - Eclipse IDE.png
          I will try to compile it and let you know later if it has worked
            Yes, changing Z to Y in that M290 command line should do what you want.
            • benkue
              Okay i have compiled the firmware but the result data are no .bin File.
              How can i make the .bin file ?
              1_1556186576861_2019-04-25 12_01_47-PanelDue - PanelDue_Readme.md - Eclipse IDE.png
              compiled Files:
              gcc builder is active
                In the Eclipse project file on github, there is a final objcopy build step that converts the .elf into a .bin file.
                • benkue
                  Thanks mr. dc42 for your fast feedback.
                  I think there is something really wrong with my compiling settings in eclipse:
                  and of course there is an objcopy in GNU Tool ARm folder but not on github.
                  What should i do ?
                  • benkue
                    benkue last edited by benkue
                    has someone compiled it with this settings successfully ?
                    • A Former User
                      I followed the instructions and it sort of just-worked(tm)
                      Think I got creative&lazy with just downloading make and putting it in the same path as the cross compiler though, as I couldn't get it to work with the internal as suggested. (possibly v2.11 from here)
                        dc42 administrators @Guest last edited by
                        @bearer said in Y baby step insted of Z baby step on display:
                        So it's working now?
                        You will find the objcopy step in the Build Steps tab.
