    BL touch setup/wiring
    896
    • williamwestonnundefined
      williamwestonn
      Working on the wiring im trying it minimize the amount of cables going to the X_carriage...
      question:"Is it possible to use one GND wire for both the BL-touch and the 3-pin PWM fans running at 5v?"
      Answer: "No, GND on fan is cotrolling the Pwm for the fans."
      Question: But if i run +5v with one cable to the X_carriage. Is it possible to use this one to power all the fans and the BL-touch without interfearing with the BL? (Running 5v PWM fans)
      Answer:
      • Vetiundefined
        Veti
        no, the fan negative is the pin producing the pwm signal for the fans.
          williamwestonn
          Oh thats a bummer... Thanks for the fast reply.
          Is the 5V always on then? Or can i connect them in single cable setup?
          Because the bl and both fans are running 5v
          • Vetiundefined
            Veti
            if you want to have nice cabling to the x carriage you could get unshielded cat5e cable.
            that gives you 8 wires of AWG 24 which are rated around 1.4 - 2A per wire. That is fine for both fans and sensors but not the heater. And you could use RJ45 connectors for quick connect/disconnect.
            williamwestonnundefined 1 Reply Last reply Reply Quote 0
              williamwestonn @Veti
              @veti My issue is that if running all connections separet ill get 11 cables total, running GND for bl one cable and all 5v together ill get 6 cables 🙂
                dc42 administrators @williamwestonn
                @williamwestonn said in BL touch setup/wiring:
                Yes, that's possible.
                Caution: when using 5V fans, make quite sure that there is no possibility of a short between +5V and a 12V/24V heater wire. Such a short will damage the Duet.
                williamwestonnundefined 1 Reply Last reply Reply Quote 1
                  williamwestonn @dc42
                  @dc42 thanks for the imput! I think i will put the fan, motor, sensor wires another route after the tube leading from the X carriage to prevent having 5, 24 and 230v in the same place. I guess a 24awg cable for 5v and the rest connected via Cat5e(26awg) is good anought?
                  Thanks 🙂
                    Thanks 🙂
                    Why do you need 230V going to the X carriage? That sounds rather high to run over Cat5e cable. The table at https://en.wikipedia.org/wiki/Category_5_cable suggests that the specification for Cat5e is 125VDC max.
                      williamwestonn
                      heh sorry for not explaining that well, there will be a 14awg cable for a heater that will go half way up to the carriage, i will probably put that on the other side of the printer instead of how i designed it to go 10mm to the right from the 5/25v cables. There will be cable deviders on the printer so ill do it as safe as i can 🙂
